Have a slight light creaking going on somewhere behind the dash and think I noticed it’s from that central vent piece too! Driving round holding bits to see if I can make it stop or exacerbate and I think this is it. So that and the classic sunroof will get rid of most of my interior noises. Still gotta read up on the sunroof one - sit in the back and pull it down or something!
Good work on the speakers and MIB too - car’s in much better shape than when you bought it!
  • Replies 77
  • Views 8k
  • Part 2 The car was originally supplied with a pump and goo repair kit. The goo was now out of date and I travel quite a bit for work so it makes me nervous not having a spare. I was keen on having a
  • Binx1310
    Binx1310
    Now fitted on the car and much better clean look I was after.
  • Binx1310
    Binx1310
    A couple of jobs done today. Replaced the drivers door inner seal as the original one had worn from driver getting in and out. The second hand one I got from eBay had a little wear but hadn’t split s
Cool White LED torch installed. Part number 3T0947417F is from a new Tiguan, multivan or T6 caravelle and is a straight replacement.
It’s B E A utiful. The last yellow light now gone! Doesn’t come out great on the photos but I’m very pleased! Great find by @Danoid
Before
After
So is this a pre-FL thing where the interior light is a torch? Mine is just a fixed light although its a cool white rather than yellow.
Only downside is because it sits on one side only as soon as you put a big bag on that side you can't see anything else in the boot in the dark. Would be good to replace it with a couple of short strips under the parcel-shelf supports (hatchback only I appreciate)
Recently Browsing 1
