Central locking/ door not unlocking
Hi all. I've got an 08 plate Roomster and have an issue with the doors. The drivers door locks and unlocks but when the door opens it doesn't register as being open. The internal ligjt doesn't come on, and even with the door open the car locks re-engage bout 30 seconds later. This is an issue that I can sort of live with. The other issue is the front passenger door won't unlock at all, even if I pull the handle from the inside, this is the big issue for me. I've taken the drivers door panel off to have a look and it seems the controller is connected to the window winder. Would the drivers one controller both doors or would I need to replace a separate module for each door. I've also read that there could be a totally separate controller either in the dashboard or near the steering column. Would anyone be able to shed some light on this. Also would it be a case of just plugging new parts in(Ebay 2nd hand) or is there coding needed. I really am clueless.
Thanks in advance for any advice and help
If the dash isnt showing open door or internal light coming on then it might be the door switch thats failed or broken wire in rubber gaitor at pillar. My mk2 octavia opens driver door and then on second press passenger door and boot. keeps coming up with message check deadlock but no idea what it means.
Alasdair
  • Sponsor
The window motors wouldn't need coding if you bought matching part numbers but I have a feeling that broken wires in bellows at either or both A-pillars will be found and mending those will solve the problems.
Thanks both ill check those out. Leared loads from YouTube fair play, never done anything more than change a light bulb up to now. Definitely been an experience
