P25AB00 Piston Cooling Oil Control Circuit High - Superb
Meant base of actual engine bay fuse box as in picture above. Think there are connectors underneath to ecu etc. Not unknown for a pin to be coroded or socket opened up enough to make bad connection especially if moisture is present.
Alasdair
Also you can check and R8 which is related to Engine electronic components
Recently Browsing 2
