ODB eleven
Has anyone got one on Pro...i was under the impression that SFD was unlocked but i cannot find it anywhere ?
Superb 3 dont have SFD
Oh right i was under the impression they had SFD 1 ? 2023 by the way.
Edited by MP74
Go to Settings in your OBD app, towards the bottom there is an option called Control Unit -> "Unlock SFD automatically".
default is "Disable"
i'm assuming changing that to Enable should cover u.
as far as i know - facelift mk3 Superb have SFD on some control units.
Edited by JR RS
Cannot find that in my device at all ?
What phone do you use ?
The only thing i get under 'settings' is this
Pro Account?
Yes pro ? Unless ive done something wrong here bjt i cant understand it ?
They r two versions of the OBDEleven app - OBDEleven VAG vs OBDEleven OBD2
I'm using the OBDEleven VAG version, Google Pixel phone (Android).
I have a Pro lifetime account.
Edited by JR RS
It’s in this section on mine under other and then settings.
What phone are you on? What app?
I found it using the Vag one but the new app is way better and seems easier ...however i cant seem to do much on it.
EG ive tried to change the 'inspection days which ist used 10 credits for and also says its changed in the app but ky car is still showing it.
Really wishing i bought a different device now bcz this is useless even in pro version .
It’s the VAG version. I have a pro lifetime account and it’s running on an iPhone.
The VAG app version is better suited to us, i.e. VW, Audi, Skoda, Seat etc etc.
Hence the VAG name for the app.
The other one is less useful as it's more generic to cater for other car brands too.
It does different stuff, but not as useful when it comes to Long Coding and Adaptations that u use with the Pro.
Edited by JR RS
I used up 20 credits resetting oil service and inspection and its not even changed anything...im beginning to think this is useless
You don't need any app to do the service reset: -
Thanks. AG Falco
Thanks. AG Falco
This will change your service interval to a fixed interval.
There’s one on you tube for the VC as well. Think it’s on a seat version, but basically the same sequence to reset the service interval without using the obd11 app.
