2024 Skoda Scala (20k km) AC failure – Evac & Recharge diagnosis question
Hello everyone,
I’m writing from Germany and could really use some insights or similar experiences regarding my AC issue.
Two months ago, I bought a Skoda Scala (2024 model, 20,000 km / ~12,500 miles on the odometer). The car is an EU re-import and comes with an extended factory warranty until 2029.
Recently, the AC has started working extremely poorly—there is barely any difference in temperature whether it's turned on or off. Interestingly, whenever I turn on the AC and activate the "Air Care" function, the system actually starts blowing hot air into the cabin instead of cold air. I also checked the aluminum AC lines in the engine bay while the system was running, and they do not get cold at all.
I have two main questions for the community:
Why does the system behave this way when "Air Care" is activated, throwing hot air instead of cold?
Is it normal, or even possible, for an AC system to be completely empty after less than two years?
I already have an appointment at a local Skoda dealership next week for a full diagnosis and recharge. Since the car is an EU import, my selling dealer directed me straight to Skoda for any warranty claims, but he did promise to cover the costs for the refrigerant recharge out of pocket.
If they do a full evac and recharge next week, will they automatically be able to detect where the fault lies?
I would highly appreciate any insights, technical explanations, or advice you might have!
Best regards from Germany,
There can be many reasons why a car AC system has lost its fridge gas, from stone strike to the exposed front condenser to poor build quality of the evaporator which is inside the dashboard are - or even failure of the system pressure sensor - VW Group have a long history of revising this part to improve it, though I'd think that pressure sensor failure/leaking is more of an industry wide issue than just VW Group.
Guessing is really not the way forward, your car's AC system needs to get checked over by a proper car HVAC operator - then repaired as necessary.
Getting your local Skoda workshop to do this is one way to maybe benefit from your warranty covering the costs - but maybe not the best plan for a quick and proper fix.
Hey, thanks a lot. I checked everything in the engine bay again today and can't see anything broken. I do have to go to the Skoda workshop, right? Because of the warranty? The dealer I bought the car from said so too. It does still blow cold air, but only slightly, and the compressor engages as well. Only Air Care gets warm.
Going to a Skoda dealership's workshop to sort this out is the only way that you might get any help money wise from Skoda.
So really the choice is yours to make, try to get it sorted out FOC via warranty at a Skoda workshop and hope not get hit with lots of "out of scope" extra costs, or take it to a proper car HVAC specialist and get it sorted and maybe maybe end up paying less.
Life can be a bit of a gamble at times.
Its a no-brainer in my opinion, I would return it to a dealer to grt it sorted as its still got its warranty.
Hi, do you know anyone with an OBDeleven? The "Advanced Live Data" has some useful information, especially 'Refrigerant Pressure', which could indicate refrigerant loss (There's a temperature/ pressure table on page 17 of the manual provided by Arkaig here) Here's a screenshot from my car, which has manual AC:
Edited by Biscayne
Image too large!
