2.0l TSI engines: what should I be looking out for AWD vehicles approaching 100k?
Hoping to purchase a 2.0l TSi Sportline/Laurin & Klement variant at some point soon. My budget may result in me seeking out a vehicle with 95K onwards on the clock. I’ll be only considering something with a full comprehensive service history.
My understanding is that I shouldn’t worry about cam chain tensioners as they go on and on. But do they?
So is there anything I should really looking out for?
I bought mine with 103,000 and comprehensive dealer history and now on 118,000 with very little to report, gearbox and Haldex servicing is absolutely paramount, check for any signs of oil leaks and obviously turbo is a crucial check.
A lot of drivers seem to think it’s fine to rev turbocharged cars hard when cold which is bad news for them so that will be down to the life it has had. I always try to buy a car with as few owners as possible as that tends to lead me to think that it has been a good reliable vehicle.
Test drive for as long a journey as possible and get it on a stretch of motorway or dual carriageway for a few miles and keep an eye on the mpg as it is a fair indicator of mechanical condition, none is guaranteed though so it is very much a suck it and see. A low mileage car can suffer abuse as much as a high mileage one.
Check out the Autotrader as there’s an ex Met police 280 with 135k for £8000 which I was assured drives without fault but might be a risky punt.
Are you any more specific?
They basically came in a low power 220bhp FWD and high power 280bhp version AWD.
The high power has had 3 different engines, the original 280 Gen3 engine without GPF, the 272 Gen3 engine with GPF, the 280 Gen4 engine with GPF. I don’t know about the FWD engine but guessing the mirror as the architecture is based around the same block.
The Gen3 versions (probably what you’re looking at) had 6-speed DSGs, the DQ250, but they changed the DQ381 7speed later on; better gear ratios but a bit flakier.
Then there’s hatchback or estate.
Never ready anything on here about cam chain tensioners so fairly certain they’re not something to look out for.
Preventive maintenance is the name of the game. The 6speed gearbox was required by Skoda for service every 40k; they changed that to 80k for the 7speed. No sense and any 7speed owner on here with fully functioning faculties has agreed they’d prefer to stick to the 40k.
If AWD then the Haldex is paramount too. It needs to have oil change and the gauze inside cleaned. Should be every 2 years although it may have been 3 earlier on.
Rear pads tend to wear first, as they’re used for the radar cruise control. Brake discs on the 280/272 are 340mm vented front and 310mm vented rear. All other models have 312mm vented front and 300mm solid rear.
Haha I bought that car from Clitheroe lol couple of this wrong with it but not too bad
What is your verdict after a few days owning it? They were going to put a couple of tyres on it and get any niggles sorted out when I spoke to them. I imagine it was well looked after by the Met Police.
They did nothing had a front assist unavailable on it and other stuff but got £800 knocked off it
Found out it’s had a new turbo and other stuff I bought new tyres for it and got booked in for the radar to be looked at at Skoda dealer
New turbo is reassuring and I saw the paperwork for repairs to the mechatronic so hopefully it turns out to be a good deal 👍
Turns out the heating isn’t working so maybe the heater matrix isn’t working not sure it just stays cold but at least when I give it the beans there’s not smoke at all so that’s good it’s a good car drives great but it does have it problems
I’m sure that a search on here will turn up similar issues and hopefully solutions
Good chance the bags burst in the coolant bottle and blocked the matrix.
Oh right is it expensive to replace and fix
Check the expansion tank for Mit Silikat on the top. If it’s on it then it has a bag in the tank. They were prone to failing and blocking the system, taking the matrix with them.
There is an official VAG flush but the matrix is normally in need of replacement when this happens.
I and others here have removed the tank and replaced it with a silikat free tank, and some without the double skinned inner chamber have been lucky enough to remove the bag with long nose pliers or something similar.
Ahhh thankyou very much do you reckon ŠKODA dealer will do that for me
They will do it at a price.
You’d be far better off talking to a good VAG independent garage IMO.
@Jameshazza this. Look for a decent reputation independent in your area. You’ll save on labour costs and decent Indy’s will do a better job than dealers on occasion when the technical manual doesn’t allow for everything (classic example is haldex service where dealers change the oil but don’t clean the gunked-up gauze on the haldex pump).
Ahhhhh that’s annoying will have a look 👀 f any vag specialist near me
You're not that far from AwesomeGTI - probably a little more margin in the price but they know their stuff.
Will give them a shout thank you
