On mine, after the update, the shop application is in a different tile position:
top-row far right.
Previously it was bottom row far right...
After a week, I have had no further updates so it seems 0334 was the enabler to solving the issue for me.
Gabbo
  • Replies 71
  • Views 6.8k
  • 5koda51mon
    5koda51mon
    I have had this same issue for a couple of months. Car was in Edinburgh dealer last week and asked them to look at it before the warranty runs out next week. They kept it for whole day and then told m
  • I'm still getting the Application update every day, its probably been 2 months now, I've done a lot of Googling on the subject and found its a Skoda wide problem, happens on any model, it seems owners
  • M4keSh1ft
    M4keSh1ft
    Hello, Yes, I'm also experiencing this on my 2021 Superb MK3 FL, doesn't prevent me from using the car so I'm not planning to take it to the dealer before my next scheduled maintenance though.
I've been out today in the car and it's updated to version 0334 successfully! Two problems that I had since I bought the car two years ago was that when I pressed a location pin on the map that I want to go to, it came up with the address as England, Deutschland and also, when I looked in Traffication, it showed the traffic laws for Germany but it never issued any notifications for the UK. The dealers tried to fix it but without success and said I'll have to wait for a software update and at long last it's done. It now shows the address as United Kingdom and the traffic laws for the same. I'll have to wait to see if I get any notifications now as I've said yes to all the options, so hopefully something will happen.
0339.323 installed successfully yesterday. I'll check if this solves the problem...
Our kodiaq is still getting daily update pushes. Still on 0302
My colleague was asked to bring his car in to have the update after he complained about the daily shop updates.
If your car is still in warranty this seems like the quickest solution...
Is the 323 update available for download and manual installation somewhere?
Gabbo
Note: Version 339.323 was one of the automatic updates from the online shop for me.
Sorry I meant the infotainment update 0334
Gabbo
On 03/10/2026 at 22:48, Bap33 said:
4th day, still no new update. 🤞
Still having the issue, assume I'm on an old FW version - is that the fix, updating the FW?
Is there a simple guide to doing that?
Yes the OTA update 0334 for the infotainment seems to fix the issue...
If you have the "connect services" subscription then you should receive it automatically.
If not, you can ask the dealer to do it, because of the daily updates they may accept as it's really a "Bugfix".
Otherwise there is a manual way to update the firmware cus USB I think.
There are some links on the forum somewhere.
Gabbo
Gabbo
If that's the app that lets you lock the car, start the heating etc - yes I have that. Always have. Still no OTA update other than this daily UI update one.
Is there a way to trigger it to start either in the car or on the app?
Have never been to a dealer with this car, its 2021, so hardly under warranty or anything. Have the SOS error too at the moment (and the charger flap fail, which is going to get fixed next week)
Gabbo
Ah that’s interesting. I get the daily updates but don’t have connected services so will I have to do full fw update manually?
The kodiaq is due to go in for bcm recall so may ask if they can do it then too.
Edited by Binx1310
If you can get the daily updates for the applications then I don't see why you wouldn't get the OTA infotainment update too....
It was released quite a long time ago so I assume that the roll out is slow.
I'm not sure if there's a way to force it...
I'm also getting the daily update messages and have been for some time, the car is fully connected with active Care Connect & Infotainment Online services but no OTA update for me so far. I've begun to ignore the messages.............
There was a page somewhere on the forum where you could download the flash files for the infotainment (3rd party so comes with some risk) and instructions for how to do it.
Does anyone know if this can be used for the Superb infotainment too?
1 week later. No update for a whoooole week. Problem seems to be fixed, now!
Another one here on a 2021 plate and still receiving the frequent small updates, and no sign of the biggie to fix it.
Would be nice if it could be forced. I'm not putting non-official updates on either, these cars are bug-ridden as it is.
My colleague had the update done at the dealers but his car is still under warrenty.
As this is clearly a SW bug perhaps they would at least start the update for older cars??
Gabbo
Is there a really simple guide to manually updating the FW on a UK spec 2021 iV L&K?
This thread has contains a nice guide from one user for how to do it and where you can download the FW files from...
From memory there was another dedicated thread to this update but I can't seem to find it.
The most important is to know the firmware you have and how many steps you need to get to the latest one.
You also need a tool like OB11 or VCDS which can send the confirmation code after the firmware update...
If I understand correctly, this last part is not mandatory but it will remove a permanent fault from the infotainment unit about the update.
Sorry, all went automatically for me. 🤷‍♂️
All done now.
Using the 3 files from here: https://mega.nz/folder/6B1yxYqY#VGP-rXf4CJ5h-xnkEg_hQg
USB C Stick in the slot under the screen
Open the service menu (ignition on, press the menu button I think it was, the top left one - hold 10+ seconds until it comes up)
Then just go through the on screen steps. Takes a while sometimes to realise you need to press something, and sometimes you need to scroll down, but its not too tricky.
Then just wait until its done.
I had a quick drive after each of the 3 updates just to make sure it didn't throw any codes, but nope, all fine.
Even got that OTA update that's been bugging me for months and a message saying it was completed. Happy days.
