Radio harnesses
Hey, recently i bought a skoda felicia I break Super I, i have a 68 horsepower engine and i was trying to find how to connect a new radio on the car but i ran into a big problem firstly i how prevously a skoda felicia II but i don't think that the same interior harnesses for most part, but i remeber it was not like ont mine, i cannot connect a new radio on the plug i have on the car, i try to find an adaptator but no chance all of them are not compatible with my plug, so i need a little help, i know on some car the radio harnesses is connected on the cigars lighter on the fusebox but for me i don't find any form of document explaining all the connection of the fusebox, and i don't want to break my car on the fisrt month of ownership, So if you know how i can connect a knew type of radio harnesses i would realy value the help. oh and BTW the car is from 1995, and hasn't change radio i also send a picture of the fuse box if needed.
Edit. the radio can be turn on even if the key is not on the ignition, so i know for sure i have a direct connection between radio and battery
The two black wires are the speaker connections... Probably old 2 pin DIN connectors from memory and the beige one will be permanent live, ignition switched live and earth.
If you have access to a multimeter simply probe the three contacts on the white connector to work out which is which and wire up accordingly.
Your new radio may have an ISO connector where all power wires are in a single black socket and speakers in a brown one, or all in one large black one, but you should be able to get a plug with wire tails already fitted. Like this
https://www.ebay.co.uk/itm/266294103226?campid=5339147365&mkcid=1&mkevt=1&mkrid=710-53481-19255-0&toolid=20006&customid=EAIaIQobChMI77-sp43_lQMV8pRQBh2QrgSjEAQYAyABEgIekPD_BwE&loc_interest_ms=&loc_physical_ms=9046365&adtype=pla&gad_source=1&gad_campaignid=23835726846&gclid=EAIaIQobChMI77-sp43_lQMV8pRQBh2QrgSjEAQYAyABEgIekPD_BwE
The internet will tell you which connection on the plug is for what (speakers, live, earth etc.) so simply splice your existing wiring into the tails on the new plug.
Edited by skomaz
So if i'm lucky i can find one online and if not, a creation of a new plug is required ok ok thx for the help
