Headlights problem
Somebody can help me please to know what the hell of bulb I need or driver module for my car ? I try to find what k8nd of bulb I need ,or driver module, because on left side the short and long beam stop to work and when I try to find what I need , TOTALY different answers : LED, XENON, on Halfords H7( illarios no way H7)...I attach a pic of my headlight, maybe somebody can help me, for sure is not MATRIX.There are 4 cavitys and I can't see any kind of bulb/led/xenon, the source of light is somewhere up inside those cavity, two for low beam, + 2 for long beam.Many thanks.
Edited by Milet
Did you have a look on the upper face of your head lights ? If I remember well, bulb type is written on a sticker. 🤔
Giving the MY of your Superb, could help too… 😉
Those r facelift mk3 Superb headlights.
Doesn't look LED nor Matrix LED.
They are lit by LED, same type as on my UK 2020 SE model.
LED strips hidden along the top inside, with thin daylight running light strip along the bottom.
Surprised that both main and dipped beam stopped working. Maybe a wiring fault rather than the LED’s themselves??
Does the daylight strip light still work?
Bad news - I believe- is that they are sealed, no way to change the LEDs.
Edited by Shuggyboatsuperb
Addition
Yes..bad news, I removed and the driver unit its inside , I have only 2 opt : to open it and check for driver module, or to buy anothe headlight , but after about 3h searching on ebay, found only one wich I think is fitted, wai for seller to reply.20260803_152234.jpg20260803_182632.jpg20260803_182626.jpg20260803_143845.jpg
