Kamiq service/warranty question
My Kamiq was registered in November 2024, but was last serviced in September 2025. In order to satisfy the new car warranty conditions, do I need to have it serviced in September or can it wait until November. Is it strictly 12 monthly service required?
Ask the supplying dealer and get a written answer.
A lot depends on the mileage of the car. If you are on the mileage limit then get it done. You don't want to be arguing if you have a problem in year 3.
Our Kamiq was a bit late for its second service as the dealers leadtime was bonkers. Dealer assured us it'd be fine (famous last words).
However if the car was on longlife servicing then it could go 2yrs between services (18500 miles) so I don't see why it should be problem. I suppose, as the first service is basically just an oil change and the second is a more extended inspection, then they might say the inspection is overdue.
Message now come up on my dash for engine oil change, is this a service or just oil ?
Read the Warranty. That is a Oil & Inspection Service. (Oil Change and look see.) The Warranty requires the Vehicle serviced to the Manufacturers Recommendations, Schedule or Regime. Well it left the factory on Variable / Flexible Oil Service regime. If changed to Fixed Oil & Filter Services that is when the Service or Oil Service or Inspection service shows. 9,400 miles / 372 days. The Fixed Service Regime is not Recommended, scheduled or advised untill some Tech / Fitter changed it to that.
Edited by Evolution13
Our (daughter's) Kamiq is just coming up to 3yrs old too and dealer service manager said (by emai) that it's an oil lubrication service. Which I believe is literally just an oil and filter change and some basic safety checks (lights. horn etc).
That's different to what the Skoda website says, which says at 3yrs/30K it should have a "Oil and inspection service with Extended scope".
The first two services were included with the deal for the car and I'm sure I recall reading that they were just oil services, plus pollen filter at year 2. That would fit with what the website is saying for year 3.
There's a quite ridiculous difference in price between the oil service and oil plus inspection. Especially bearing in mind the car will be MOT'd too, which is a pretty thorough going over.
I'm annoyed to have to pay at all - slipped up really, should have had the car left on longlife servicing so it wouldn't even be due for its second service yet. Having said that, I'm not mad on the car not being looked at for 2yrs, and leaving oil in for 18,500 miles probably isn't a good idea.
^^^ Perfect. Fixed Regime chart not accurate in all. But as far as Extended Scope the idea is @ first 3 years then each 2 years. As Brake Fluid used to be, but now they say each 2 years. Not all DSG are at 40,000 miles. Cambelts also changed advice.
Recently Browsing 2
