Fabia 1.2 HTP starting issues
Hello!!
I've been having some starting issues with my Fabia Mk1 HTP recently. Sometimes it doesn't react to the key being in the start position. No cranking, no noise (other than the fuel pump buzzing in the back). After some fiddling with key, or a fast turn it starts and runs fine.
Now, after replacing the battery the issue seemed to go away and it had been starting perfectly. Two days later it looks like the problem is coming back, but now the fast turn of the key doesn't make a difference.
Also, it doesn't look like it matters whether or not it's a cold start.
What could be causing this?
Wire to starter motor solenoid gradually breaking, just outside the cable entry of the connector at solenoid plug, generally.
Could also be a bad ignition switch especially if it works when turning key fast or fiddling about with it Pump I assume will prime at pre ignition etc but it may not be making proper contact when turning to start. Could also be loose connector/broken cable at back of switch.
Alasdair
Thank you guys! I've got a small update. It turned out to be uncleaned battery leads. After brushing the clamps with some sandpaper the car starts reliably now.
There is a occasional hiccup at the start position though. I turn the key, hear constant buzzing when holding the key at the START (not the ignition prime) and nothing else happens. It's so rare that I won't bother for now
I would suggest taking a good look at the switch and the starter solenoid, very likely to let you down in the future.
