Dashboard rattle from 2023 Octavia centre vent/speaker?
Hi all, been bugged by a persistent rattle within the cabin at ~1200-1400 RPM. I think the noise comes from the central vent/speaker at the front (top?) of the dashboard, as I can stop the noise if I put my hand on the plastic speaker grate there.
Anybody have ideas for how to remove the rattle? I've tried wedging something into the edge of the plastic vent to hold it, but I couldn't find anything small enough.
I removed the mesh over the speaker and wrapped its clips with textile tape. That solved the problem for me. Some people were saying the speaker itself may be badly attached and rattle, but I checked mine and screws were tight as should be.
How about
Oh that's a good idea. How did you go about removing the cover?
So just go carefully with whatever trim tool you have handy to remove the vent. That will probably get you a better chance to get the speaker cover off. Here's a picture of the clips under the grille you need to get at.
I did not touch air vent, only removed speakers mesh. It simply unclips, so slide thin trim tool in the gap and pull. If I remember correctly, to remove air vent you'd need to remove this mesh first, anyway.
Thanks for everyone's knowledge and insight. I've removed the speaker vent with a trim removal tool, and wrapped thin fabric tape around the legs of the clips. It's almost removed the rattle completely, although there is still some very slight rattle.
I suspect it's stemming from the contact points of the plastic vent to the top of the dash, but I think it's not noticeable enough for me to continue taping.
I have had this same issue with the centre speaker grill and the heads up display cover, when going over certain surfaces they would start to buzz, nothing crazy but very annoying, if you put your finger on them it would stop.
I have fixed them both by using a trim pry tool to lift them up and unclip them, then used Tesa Wire Loom Harness Tape Amazon link but I did not put in on the leg of the panel, I put in along all of the ridges along the edge, as I think this is the part that is tapping on the dash.
Since doing this it has been totally silent.
