Octavia RS AFS (Bending) Lights don't work
Hello everyone,
I have pretty weird issue with my bending (AFS) lights, they dont bend anymore 😁
I don't have any error code on dash, and when connecting VCDS I don't see any error messages for headlights either.
I tried testing the ligths bending left and right with vcds and they work totally fine both of them bend left and right. I also run learning usin VCDS basic coding, and it said: learned.
I also checked a 10Amp fuse, switched it with another 10Amp fuse for AFS and it still doesn't work.
It feels like AFS is simply switched OFF, but googling arround I found out that there is no simple switch off/on for AFS.
I did switch off cornering lights with fog ligthts using VCDS, and set washer headlights to off, but that shouldn't switch bending lights function?
Did anyone had similar problem? Am I missing something, maybe I can do some sort of AFS reset or there is a setting to switch them on/off?
Turn your cornering lights back on and see if that brings them back.
My Sharan has AFS lights and when one of the static cornering lights bulbs was out it disabled the AFS headlight function.
Also, there is definitely and off switch for AFS as I have the option on the display to disable bend lighting, so there must be an equivalent VCDS option somewhere.
Here is the option on the display.
Update: I feel stupid now, but in my offense it's Skoda's fault for not naming things correctly 😄
So I just went into the instrument cluster, navigated to Assistant > Enabled CORNERING lights
I thought cornering lights were those with fog lamps, and dynamic or bend lighting like shown in comment above should be AFS switch ON/OFF, but I was wrong.
After enabling the cornering lights I now see them move when I turn.
Thank both of you for your comments!
PS. The skoda is from 2009.
