Spacesaver spare wheel
Just wondered if anyone could recommend an aftermarket space saver spare wheel and tyre for a 2025 Mk4 Fabia Design edition. Thanks in advance.
Got mine from The Wheel Shop on Ebay.
Wheel plus full kit (jack, etc) for approx £100.
The below foam and jack kit can be ordered for the Fabia MK4 from any VAG parts department by quoting the relevant OEM part number, ie. 6VA093860A. The VAG parts department can confirm whether this is correct for your vehicle by reference to the car's VIN number. The Czech price on "skoda eshop cz" is 2079CZK which is about £74.
The below foam and jack kit uses a 185/65R15 5.5Jx15 ET40 5/100 57.1 spare wheel.
Fabia MK4 foam and jack kit (includes everything except for the actual spare wheel) (OEM part number 6VA093860A)
No image preview
Sada pro výměnu rezervního kola 15
Určeno pro: Fabia IV.
Alcar 4055 5.5Jx15 ET40 5/100 57.1 steel rim (for Fabia MK4)
https://www.mytyres.co.uk/rims/details?vehicleId=1360399348768339044&rimCode=ALCAR4055
Alcar 4055 5.5Jx15 ET40 steel rim with fitted 185/65R15 tyre (includes valve and balancing)
https://www.mytyres.co.uk/cw/tyre-selector?share=&vehicle_ids=1351328927594845284&sortCode=none&limit=15&rimCode=ALCAR4055&rimType=steel&sizeTyresOnCW=noChanges&season=so&price=&brand=Uniroyal&brand=Vredestein
Edited by Carlston
These 2025 and 2024 forum topics discussed (in some depth) spare-wheels for Fabia Mk4 cars.
https://www.briskoda.net/forums/topic/533394-fabia-spare-wheel/#comment-5952581
https://www.briskoda.net/forums/topic/522682-spare-wheel-and-central-tool-holder/
The 'genuine' Skoda Fabia Mk4 spare-wheel + tool-kit is currently advertised here at £225.15 (Sale price)
https://skodapartsdirect.co.uk/product/skoda-fabia-2015-2026-spare-wheel-tool-kit/
Sorry - I note that the advert I referred to in my last posting does NOT include the spare-wheel!!!
The Skoda part number for the spare-wheel (including tyre) is 6V0601011M and should be available for around £215.
(Delivery charges extra.)
Edited by DerekU
The OP has a Fabia MK4, not a Fabia MK3.
6V0093860B and 6V0601011M are both Fabia MK3 part numbers.
Edited by Carlston
Thanks, I thought I had subsequently posted the correct part numbers, but clearly not!
Anyway, these two UK adverts shown below show the relevant part numbers for Fabia Mk4 cars and (as you said above) they are 6VA601011F for the spare-wheel and 6VA093860A for the tool-set.
Wings SKODA
No image preview
SKODA Spare wheel FABIA IV
15“ Spare wheelWhen choosing a spare wheel from the ŠKODA Genuine Accessories range, please refer to the information in the registration document to check that the dimensions of the spare wheel corres
Wings SKODA
No image preview
SKODA Toolkit for Spare wheel FABIA IV
The Spare wheel set is designed for drivers who prefer to use the spare wheel instead of the puncture set in the event of a puncture. Spare wheel set - includes all the necessary tools for changing a
(I THINK the spare-wheel for a Mk3 should be OK for a Mk4, but a Mk3 tool-set would definitely be unsuitable as the Mk4 requires a different design of jack.)
3 hours ago, DerekU said:
...I think the spare wheel for a MK3 should be OK for a MK4...
The Fabia MK3's spare wheel (185/60R15 6Jx15 ET38) has an outside diameter 3.0% smaller than the Fabia MK4's spare wheel (185/65R15 5.5Jx15 ET40).
Additionally, the Fabia MK3's spare wheel (185/60R15 6Jx15 ET38) has an inflated width that is about 6mm wider than the Fabia MK4's spare wheel (185/65R15 5.5Jx15 ET40). The offset is also 2mm different, ie. ET38 vs ET40.
That additional 6mm in inflated width, might result in the carpet being lifted...but you would have to check if you just happened to have an old Fabia MK3 spare wheel lying around. The 2mm reduction in offset might also add to the carpet lifting problem that can occur when the wrong spare wheel is used in the spare wheel well.
Edited by Carlston
I went directly to the Wheel Shop in Manchester for my spare wheel and tools. Very helpful and delivered in a couple of days.
Will a full size spare eg this one : https://www.ebay.co.uk/itm/168359344547 completely fit in the under-boot recess? Also,I have not been able to find a full size spare complete with tool kit - any ideas apart from Wheel Shop who do not stock it, or Skoda who charge silly money.
1 hour ago, RedSkoda2 said:
...I have not been able to find a full size spare complete with tool kit - any ideas apart from Wheel Shop who do not stock it, or Skoda who charge silly money...
The below kit can be ordered from "skoda parts com" for 108.14 Euros (about £90.62) which includes shipping to the UK. It includes everything, except for the actual spare wheel...which can be purchased separately. The official spare wheel for this kit has a specification of 185/65R15 5.5Jx15 ET40 5/100 57.1
Tool kit for Fabia MK4, kit includes: 1x polystyrene molding, 1x jack, 1x wheel nut wrench, 1x screw-in rosette, 1x reserve strap. 6VA093860A
https://www.skoda-parts.com/spare-part/6va093860a-spare-wheel-replacement-kit-skoda-43264.html
Mytyres can supply a 185/65R15 5.5Jx15 ET40 5/100 57.1 spare wheel, ie. tyre is fitted and balanced to an Alcar 4055 5.5Jx15 ET40 5/100 57.1 steel rim for under £120 (depending on tyre choice) including shipping to the UK.
Edited by Carlston
Thanks for this Calston. It's amazing that Skoda UK sell this for £225 and that is 'on offer'!! However, the tyres on my Fabia 2026 are 195/55 R16 and the part number for the kit is 6VA0 938 60B rather than 60A. Can't find that one on Skoda-Parts site though.
Recently Browsing 1
