Software upgrade
How does one upgrade the software of my 2015 Superb?
I am increasingly finding that I am 'driving through fields' and now the BT blue tooth will not connect to my new Samsung phone.
Is there a way of upgrading the car's software?
There is. What version do you have at the moment? Go to Menu, Settings, then System then scroll to the bottom for Software Version or something like that.
And do you have twisty knobs (Amundsen) or just touch screen buttons (Columbus)?
Bluetooth is A2DP/AVRCP BT6506
Hardware is Part no. 5Q00035874A
H24
Software 0245
Navigation Part no. 5L0051236E
0430
ECE 2015/16
Media codec 2101.0.0.10
one of those must mean something!
@JR RS has done a brilliant guide. Make sure you have a good battery charger connected as a failed battery during this process can be catastrophic.
H24
Software 0245
0430
ECE 2015/16
based on the hardware part number - u have a MIB2 Amundsen unit.
the guide i created is for a MIB2 Columbus.
hence i would refrain from using the how-to-guide i created.
i don't know wat the firmware upgrade process is for Amundsen unit.
Ah yes. Good spot. I think the process is the same but need to make sure you get the right update package.
If you put your existing software train into MiB helper it will tell you the latest version. If there is more than one version between your existing and current one you may have to upgrade in stages
https://mib-helper.com
Simple SD Card, nur for junp Firmware train you have to Patch
