Are drum brakes rear axles different to disk brakes?
Hi to All,
I’ve been a non-registered reader since August, when we bought a 2011 Fabia 1.2 TSI manual for my son as his first car. It needed a bit of work, and I’ve now created an account to ask a question.
One of the rear shocks had failed (the other one was replaced by the previous owner earlier this year to pass the MOT). While replacing the it, same as in @GrumpyBob 's thread, we noticed a rust hole in the rear axle beam near the lower shock mounting point.
After some digging I've found out that there are two OE part numbers - one for drum brakes and another one for disk brakes.
Are the two versions physically different, meaning they won’t fit each other or just some bits and pieces that can be swapped?
I assume there must be a reason for the different part numbers, but can’t spot any differences in the pictures.
The reason I’m asking is that some aftermarket manufacturers list both OE part numbers as compatible with the same axle beam (this one for example), while others specifically list only the disc-brake version and don’t seem to offer a separate version for drum brakes (this Diederichs one I'd really want to buy if it fits)
Appreciate any advice or information.
Edited by V12twinturbo
Picture added
Buy the brake disck rear axle and you will need these parts, https://darksidedevelopments.com/products/rear-brake-drum-to-disc-conversion-for-skoda-fabia-5j-mk2.html (the fitting point in the frame are the same even for the shock and spring), maybe consider to fit polyurethane bushing in the rear subframe to increase the handling.
Let me know if you want to upgrade the brake setup to fit 256mm vented rear discs (and to increase front to 288 or 312mm)
Edited by Jack25
Not sure, but in this thread
I appear to have looked up by VIN the suggested replacement part for a car with drum brakes and got the part number that's described as for disc brakes, so they may have rationalised part numbers.
Can look up your suggested PN if you can tell me VIN.
Typing at same time as Jack25 above, whose info is usually excellent, so have a read of his link. ^
Thank you very much!
Thank you @Jack25. As much as I’d love to do that, it’s probably not worth it for a £700 15 yo clunker. 🙂 But looking at that kit, it seems there must be different mounting points for drum and disc brakes.
I appear to have looked up by VIN..
Thank you Pete! Just messaged you my VIN.
Clearer text
difference is only on places where handbrake cable mountings are welded.. new aftermarket parts have probably disc and drum parts welded.
I’ve posted the link just to let you know which parts are needed, probably if you look for the various part needed on different platforms the final prince would be cheaper
Yes, that's a good idea, thank you very much!
Welcome to the forum. Be aware that there are 2 different rear axles for mk2 Fabia vRS if getting an rear end with disc brakes.
Edited by Evolution13
10 minutes ago, Evolution13 said:
Welcome to the forum...
Thank you @Evolution13.
I hadn’t thought to search for it that way - I’ll read through those topics and hopefully find an answer.
My main question, though, is whether a rear axle beam for disc brakes can be fitted to a car with drum brakes, without converting the brakes to discs.
yes, only handbrake cable on drum goes on lower part od axle and disc brake on upper part, but cable can be fixed with strong ZIP ties, that is not a problem.
and disc version have 2 disc bracket holes. you can ignore them.
Edited by imart143
@imart143 Thank you so much - that’s exactly the answer I was hoping for!
I’ll be ordering the Diederichs one (as I understand it’s the best aftermarket option) along with the other 'while you’re in there' parts this week. I’ll post an update once the job is done.
Current/suggested part number confirmed by VIN as 6Q0500051BB.
Wondering if in that other thread the OP maybe gave me a VIN of a car he knew had disc rear axle, as that was their goal.
Anyhoo, looks like the others have solved the info shortage well ahead of me. 🙂
Thank you @Breezy_Pete .
A lot of aftermarket versions and even some remanufactured OE ones list both 6Q0500051BB and 6Q0500051AT as compatible numbers, whereas Diederichs only lists 6Q0500051AT.
So I guess, as suggested above, I’ll just ignore the two extra mounting holes and use a zip tie to secure the brake line. That way my son willl also have the option of upgrading to disc brakes in the future if he ever feels like it.
I'l post some pictures of what it looks like in the real life.
A quick update - I’ve spent some time thinking about it and reading reviews of all the possible aftermarket options (Diederichs, Vika, Imaxle, D2P, Eurosubframes, etc). Even though there are a lot of positive reviews, some feedback suggests that the weight and geometry differ slightly from the OE and in some cases it makes it difficult to install and align the rear wheels properly.
So I looked for original remanufactured ones and found a company from Poland on eBay specialising in refurbishing rear axles. They claim to sand and apply anti-corrosion paint, replace the bushings, and to have very strict quality control. They have good feedback as well. It was also the cheapest option (£100 + £17 shipping, including VAT, compared with £160-£250 for the aftermarket ones), so I went ahead and bought it.
I haven’t installed it yet, so we’ll see how it goes, but so far it looks good and solid.
Thanks to everyone for your comments and advice.
text clarity
Nice find.
Operation completed successfully. The new part fits like a glove.
Please share seller info. 🙂
Bought it from this listing on eBay. VAT was already included, but a couple of weeks after delivery, UPS slapped me with a £7 customs processing fee on top, which is still not too bad.
https://www.ebay.co.uk/itm/267743686604
Recently Browsing 2
