led lights, what happens when you are stopped at night because one or more have failed??
If you have led lights fitted to your, for instance, Fabia 4 and the lights go out, what do you do? what spares can you carry and fit?
or is it a call the motoring organisations for help?
I suddenly thought of this and realised I had not got a clue!!
My late-2023-built Fabia M4 SE L model has LED headlights and the rear foglight, reversing-light and number-plate lights are also LED units. My car's only exterior lights that have 'traditional' halogen bulbs are the rear brake, position and indicator lights (and I carry spare bulbs for those) and, when the Mk4's specification was revised (in 2025?), I believe those lights also became LEDs as standard.
Realistically, if any of a Fabia Mk4's LED lights stops working, unless the cause is something simple (eg. a blown fuse) and not the light-unit itself, there's nothing that the driver will be able to do to 'cure' the problem - and that's also likely to be true if a member of the AA, RAC etc. is called out. And, even if an obsessively pessimistic owner carried a full set of spare LED light-units, fitting replacements at the roadside probably would not be practicable.
Edited by DerekU
Recently Browsing 3
