L&K Front Fog light Bulb access?
Hi all.
I've watched the vids that show how to pull off the trim pieces next to the fog lights, but mine seem to be stuck fast.
I really don't want to yank on them too hard in this cold weather & risk breaking any of the securing tabs. One of the vids I watched the guy did just that & broke off the securing tabs when pulling on the the trim with a pair of pliers. Other owners have used their fingers but mine are not budging.
Apart from the extra chrome bits, are the L&K front fog access trims different in the way they secure from any other models? Are there any hidden pry points etc?
If anyone's got any ideas where I should be prying / pulling & with what tool to help get these trim pieces off I would much appreciate any info you can provide.
Cheers.
You can get a hair dryer or heat gun and gently warm the area. it will hopefully soften the clips etc to prevent snapping in the cold weather.
they can be a bit awkward and stiff but you pull straight forwards in line with the car, not at the angle the trim is at. That seems to be the main issue.
I am assuming it is pre-facelift. I am not sure how the facelift ones come out.
Edited by Binx1310
@Colin170CR - assuming u have a pre-facelift mk3 Superb.....
This is on my Superb MY17.
Thanks. Yes it's a pre-face lift 2016 model. Looks easy doesn't it. However, mine won't budge. The whole front bumper is flexing when I pull on the trim & both sides are not coming out.
The cold weather is probably not helping (currently 1-2c on my driveway & raining hard) so I'm going to try & warm the trim up a bit with hair dryer / heat gun & use a thin plastic trim removal tool where those locating tabs are. I just don't want to break the tabs as the guy in this video did 😒
@Colin170CR - if u get a flat trim removal tool, u can insert it between the bumper and the foglight grille at the points shown in the pic below to pry it out.
Back view....
Front view....
Back view....
Front view....
Yep. I'm going to give that a go. LED fogs waiting to go in 🤞
Finally.
After much cursing, swearing, copious amounts of WD40, plastic trim removal tool insertions / prodding & general faffing about for nearly 2hrs I managed to get the dam things off the car to access the fog light units. Surely it shouldn't have to be that hard?
Installed LED bulbs which look great & now match factory headlights. However, one re-installed trim cover is not sitting quite right. The chrome strip is not flush with the corresponding piece on the lower bumper☹️. I'll leave it for now but my OCD will not allow it remain like that. More faffing required after I thaw out & have a cup of tea 🫖.
Well done!
I found with mine the first time was the hardest, and since then they come out easily, they could well have never been removed since factory! The chrome strips clip into the main part so may well have come out a tiny bit when you pulled them off. May just need a gentle push back into position, or the overall piece may need realigning to push home.
Do your leds dim? Think most just turn off
Don't know yet. Not had the car out on the road since I replaced the fogs.
The LEDs won't dim like the normal bulbs did in the foglights.
Edited by JR RS
Yeah mine are just on or off.
Ah didn’t think so, I quite like the dimming
I do notice the on/off when cornering lights come on at low speed is all or nothing and its noticeable, but I can't say that it bothers me per se. I prefer the white light on/off over the yellow light dimming. Down to personal preference.
On 16/11/2026 at 13:21, Colin170CR said:
Finally.
I have exactly the same issue. I tried very hard to remove these boogers during the summer to replace the bulbs and even in 35c heat, they were having none of it. So I’ll try the trim tool, WD40 and two bloody hour trick! 😂
A 70 mph pheasant impact did the removal stage for me 😬
I think it might help to remove the undertray and access the clips from behind.
If you need to replace the trim part, don't waste your money on aftermarket versions. The one I bought was a very poor fit and the chrome strip deteriorated quickly.
I took my ill fitting R/H trim piece back off again today. It came off a lot easier the 2nd time around. Straight pull with two hands & gloves on did the trick. Seems one of the locating barbs had bent over preventing the trim from fully seating. I bent the barb gently back out & refitted it. It's fine now.
As D402 said above, dropping the front underside tray is another option to get access from the back. Not easy scratching around on the floor trying to find all the retaining screws for the tray unless the car is jacked up or on a ramp but, it's doable as an alternative option.
Recently Browsing 2
