Help...... desktop PC is dead!!!
Houston we have a problem......!!!
I turn the computer on and get the windows XP screen with the scrolling status indicator as usual. However, I then get a black screen with
Mine did this so I got a nerd round who thought it was a driver issue. Sent laptop back to Tosh and they said drivers are fine, it's a software problem. In the end, I had to wipe the HD and do a master reset. Have you tried a system restore from a month ago?
Nope. How do I do that?
You won't be able to do a 'System Restore', because to do so you need to get XP to load.
If you've got your Windows XP CD-ROM, you could get the PC to boot from the XP CD, then choose the "Repair" option. This might find and rectify the problem.
Did you do anything to the PC at all the last time you used it? Install anything? Was it making any "funny noises" at all? Your hard-disk could well be goosed.
... thin link gives you some idea of the process for repairing/re-installing Windows XP ...
Microsoft Article
boot off xp cd
select repair using recovery console
select 1 when prompted for xp to repair
type chkdsk c: /f
exit
restart and all should be well. have this a lot at work basically caused when the pc fails to shudown properly.
Thanks for all the replies fellas..... I'll try and boot from the XP CD and do a repair as suggested and see what happens.
I think it might have something to do with the fact the kids have been using the PC recently and have a nasty habit of pressing the off button as opposed to shutting down properly. Will have to smack there hands - again.
