Brake Pads
Anyone know if you can buy uprated Brake Pads (or discs) for an Octy II 2.0 TDI elegance just yet.
I'm not looking to do it, just looking at it from a comparison point of view with other cars.
Mine are due to be replaced soon and have been informed that Ferrodo make a decent set for the OctyII but I'm affraid I do not have any reference numbers for them.
Im wondering the same here! Considering disks and pads!
mintex do uprated ones for the octy 2
Hi
We have kept a certain MkII in Tarox
These are good discs and pads
We can also get ZeroSixty discs , these are quite a bit cheaper than Tarox
But I myself would keep clear of Green Stuff , myself and others have had problems with them warping discs
Hope that helps
Sarah
Hi
Hope that helps
Sarah
Hi Sarah,
Are these any good on stock discs, and if so how much would a full set of pads all around cost.
Hi
Hope that helps
Sarah
:thumbup:
Oooh
Thanks Dave , another thumbs up ;)
Nice
The 288`s on yours are the same pads for the 312`s , same as the mk1 Octy`s
So the price of the front ones are £79.00 + VAT and the rears are £61.00 + VAT
These are Tarox Strada pads , as used by Shifty ;)
Sarah
Yeah, regularly! :rolleyes:
Is that the latest compound? I ran some Greenstuff's in the past and they warped my discs but apparently this has now been rectified. Saying that, why anyone would pick the Green's over the Redstuff is beyond me :rofl:
Chris
Hi
To be honest , I would not know , but the problem is , would you risk it?
There are other makes out there to try , why bother?
Sorry
Sarah
Based on the write ups the latest ones have been getting, yes I would ;):rofl:
Chris
Ive now got some stradas on my furby... will let you know how they are compared to the excellent DS2500's i had on before...
.......the excellent DS2500's i had on before...
Who makes those?.
Who makes those?.
Ferodo :D
Chris
Yes the DS2500`s are from Bill @ Badger 5
Sarah
So the Octy II Elgance spec has 288mm brakes and the same set up at the 312mm octy I?
Hmm i wonder does the 312 conversion fit :P
Guys, silly question but, would fitting your own brake pads invalidate the warranty on the car ?
Hi Mate
NO it wont as long as you dont damage anything and expect it to be covered under warrany.
The 288`s are the same pads as the Mk2 Ocy`s 312mm
These have the 5 X 112`s stud pattern
Sarah
Ok thanks, so if I change the pads and the car goes in for its next service, still under warranty at this point, the garage won't say anything ? Just want to be sure
With the introduction of block exemption you do not need to take your car in to a dealer to keep up with warranty
As long as the garage is VAT registered and use of equal quality parts then warranty will not be effected
You can put on your own parts like brake pads and that will not effect the warranty either unless you damage something while you are doing it , then that will invalidate the warranty on the connecting part
Fitted OK then not a worry
Sarah
Hi Mate
Sarah
So can i get this right sarah, which Octy has the 312mm Discs, the MK I VRS did i know, but what about the MK II.
I'm just wondering of the possibility of a conversion from stock brakes on an elegance to VRS brake set up, esp with a crashed VRS TDI just appearing at a certain breakers yeard.
I guess what i am asking is can i 312mm convert these and if so which parts would i need to buy and how much labour would it be?
Thanks for the info Sarah, much appreciated
