Drop in mpg???
I think I may have a fueling issue as I'm now struggling to get more than 310miles out of the tank. Thats from fill up to fuel light coming on. In the past 380-400 was average.
Now a few weeks ago the fuel light had came on and not long after the car was struggling to start. Then on the way to get fuel it was like I was running out of fuel. Strange as the light had not long been on. Say 10 miles or so. So a fill up of shell (before was tesco) and it seemed to have solved the driving problem but still didnt seem to start like it did.
A Couple of days later I had a new set of tyres fitted and went back to the oem 205/45 size from 215/40. Then after that it got a 10K service were a boost leak was found and fixed.
Then that tank lasted 350m. Thinking the boost leak may have caused the decrease in mpg I didnt think much of it. Now the last tank has only lasted 310miles.
Any ideas?
What tyres did you have fitted? Mine has been down 5mpg across the tank for the last two fillups after my new Falkens were fitted, but I filled up again on Thursday and after a good couple of 150 mile blats, economy for that tank seemed to be back up to normal. Current tank seems to be going the same way too, so I'm just putting it down to one of those things! ;)
Chris
Changed the MAF recently?
Nope. Engines not been altered except for the boost leak.
Was thinking about the tyres as well chris but to be honest I think its a bit too extreme. A normal drive to work would record 52mpg. I now struggle to get 41mpg. mpg was never that bad on the michelins or falkerns. Both were std sizes.
Could the fuel filter be clogged. Dont think its changed as part of a 10K service.
When I had new tyres fitted all round my MPG dropped considerably till the tyres were worn in, 1000 of use and MPG was back to normal. Also check the tyre pressure this can have detrimental effect on MPG.
Des
Sounds like the dross from the bottom of the tank could have got into the filter. Try running fuel through drain on bottom if no new filter handy - beware you need a container to hold a litre or it will spill. They are normally changed at 40K, but I do air, fuel, pollen at 30 just to be safe.
Best of luck
V
just changed my filter at 41k , not a bit of debris in it , even though i've run it to 0 miles range , might be worth checking to see if there is any dirt in it
you could be right with the MAF though , has the performance dropped ?
tyre pressures ok ? no brakes binding ?
No performance drop. Original idea was the fuel filter. Not got time to check the maf tonight so thats another day. If they isnt it I'll change the filter next.
I've had a subtle clutch slip for a while now. It only shows up on the gauges when severely provoked, but my fuel economy has dropped by about 6 mpg. I'm having the clutch replaced tomorrow, so we'll see if that was the culprit. You sure your clutch is 100%?
interesting theory BryanD , lets us know if the consumption gets better with a new clutch fitted
Interesting but cant see how it would happen over night like mine. :confused: But keep us informed. Not had clutch slip for a while now. Just the DMF vibrations :rolleyes:
So far my bets are on either MAF or fuel filter.
Chris
My mpg dropped by abour 3 mpg when moving from oem Contis to Eagle GSD3's. I can feel the increase in rolling resistance but it's more than compensated by the better grip, both wet and dry, and generally better alround feel.
Well I was getting 30mpg for my journey round town.
You haven't bought any new footwear have you :P:rofl:
Chris
Just got back from Jabba with severely dented plastic and a new organic clutch. 51 mpg on the way there and 56.8 on the way back. Also much more 'attack' to the driving experience and the clutch biting higher up the pedal travel.
I think clutch deterioration really can sneak up on you. (Having said that, I've got the old parts they took out, and there isn't much sign of anything abnormal.)
Well just done a few wot with vag-com to measure the maf. Cant say anything looks strange with the results.
Next step. Fuel filter.
when we were doing the DMF/clutch recall on the Galaxy PD130 , some of the clutches that were changed were still like new even after quite high mileages
My clutch is f**ked...
yet i can still easily manage 45mpg when hoofing it.. and 55-60 on a run
I usually get 500-550 out of a tank.. thats not hangin about either
I had my brake fluid changed yesterday and I had a drop of 10 mpg. I checked everything and it turned out my handbrake was binding slighty. So I adjusted it and my mpg is back up to what it should be. Might be worth a check?
Right fuel filter has been changed so lets see how the next tank goes.
Before last night (change of filter) I had a couple more events of the engine taking longer to turn over.
I know we've had this debate on here before but how is this possible?. When I brim my tank I usually squeeze in 43 litres, that's after releasing the pressure 3 or 4 times using that button inside the fuel neck. How many litres can you get in the tank?
Des
Is there an easy way of doing that, like can you hold the pressure release button down whilst filling the car, or is it always a stop start procedure?
  • 2 years later...
Well finally sorted the engine turning over issue. Camshaft position sensor. Now with it replaced my MPG has shot through the roof. 58MPG on the way to work. :eek: So think thats what might have caused my poor MPG. Its been up and down since I started this thread. Most of the time good. But sometimes it goes through a phase of struggling to get mid 40's on the way to work.
Excellent, surprised you weren't getting an engine warning light though :eek:
Enjoy the extra MPG
