Is 300 bhp possible from the 130pd?
Hi Dave
We cn do you the clutch set up with the SMF as Baz has
We are also doing the Quaife diffs too
But IIRC I have given you a price ish
Glad to know that you got sorted with the little prob you had with that hose
Sarah
Hi Sarah :), yes it's all running fine thanks now :), albeit a bit slower. Expected of course, as it's not mapped for the turbo. I was just seeing if anyone knew particularly what clutch would be best, as I only want to be buying the one, and the one you said looks favourite.
@ Snoopie - no problem, just I've seen so many threads that turn into a RR debate, I just thought I'd roll my eyes.
  • Replies 52
  • Views 9.9k
Im running the Heilix SMF with aluminium pressure plate and that is really good :D bit noisey on idol though :(
I wasn't RR debating. Simply determining, if the Kelvar clutch can be used on a 500lbs of torque vehicle, it must be suitable .. for a 400+ lbs of torque Fabia. Considering either RR was as accurate as the other. ;)
