Pinky,s Got A Wobbly.....................
................Gear lever, bit like a joy stick on an aircraft.............." Anything I can do to make it a bit tighter "...........5th gear is over by the door....:)
cut down the length of the shaft???
Hi
There are LOADS of plastic bushes on them
It could be them that require replacing
Dont let her get the better of you , and treat her right with a few nice new bushes :confused: that dont sound good does it :lol:
Sarah
i cut mine down, much tighter!!!!!!!
Hi
Sarah
Thanks Sarah.......I asume these bushes are under the car in the linkages. From the bottom of the gear lever to the gear box??
yeah, the linkage is made up of two long metal rods, one is a fixed rod which is there to maintain a fixed distance between the gearbox and the gear lever pivot. and the other is attached to the bottom of the gear lever and is connected to the gearbox selector shaft.. this is the one with the plastic bushes in.
