Official 60 in 6.88 seconds but still...
... capable of superb economy. This was taken after I arrived back at Exeter. :cool:
71.4 :cool: Done at 70mph cruise control for most of the journey
215 miles done
Range apparently left on my tank...
... despite having done 200+ on it already. :thumbup:
Oh yeah. Got fastest time on 1/4 mile of 15.268 :cool: Not bad considering the start basically involved lighting up 2nd gear. Traction? What traction? 0-60 of 6.88 on the same run. Damn Chris (Ellis - We went in tandem down the 1/4) beat me by 0.03 of a second as well. :P :rofl:
  • Replies 103
  • Views 7k
You did 70 mph all the way down the motorway! I didn`t realize the traffic was that bad.
I had my speed limiter sat next to me. AKA "mum" :rofl:
So after all your modding your car is now a bit slower than a (remapped?) Octy vRS? :P
Chris
Not bad going that though really right ;)
Chris
0.03 seconds slower over the 1/4 mile yes. :D
Is that with Nos Jason?
It was, but what actual effect it's having I'm not sure. Was fairly clean on most runs I did.
Guessing the fuel economy is with propane running at a good flow rate too ;)
Now to get your Peloquin fitted - I am sure you can do a LOT better with proper traction.......
Good Going mate:thumbup:
215 miles done
You had travelled 215 miles and still had an indicated 540 to go?
Wow...
I saw you on the sprint strip and am sure you would've got a much better time if you hadn't been sat there with the wheels spinning! :) Was the same for a lot of people, except the Scirroco that was doing 0-60 in the high 2's!
Ok so from looking at the fuel guage you have done 221.2 miles with 1/4 of a tank of fuel (lets assume it goes down linear).
So given you drive the rest of the tank like that then you could get 890miles from the tank & as the fuel goes down it getting lighter so will use even less fuel.
This is clearly a message to those of you who state you never really get over 45mpg your driving your TDI incorrectly.
For the poster what a result - It would be good if you brimmed it now and calculated your true MPG so we can have a measure of the accuracy of the trip computer.
Or possibly it may be down to the modified air intake, FMIC, remap, hybrid turbo, piddly rear wheels and propane injection? ;)
Chris
No. I am infallible. I am the worlds greatest driver and there can be no way that I am driving my TDI incorrectly.
I recently found this stuck to the back of my car however which would explain a few things;
Im not so sure - 71.4 is incredible perhaps it was achieved by driving the TDI on the torque wave not changing up at 4000rpm to get peak power ?:)
Red line chasing for that marginally quicker time will get you to your destination in hardly any noticably quicker time use more fuel stress more parts risk other road users more etc.
Cruise control set to 70mph is fantastic.
You'd have got more if you'd driven yourself mate - I used to find my cruise dropped my mpg.
Not bad results from a PD100 though :thumbup:
Its a PD130 now... ;)
Or maybe holding a constant 70mph (which is off boost?) for 200 miles? ;) Also bear in mind that this is with propane injection too, which will increase diesel economy, but possibly not save on cost per mile....
Chris
So lets get this straight. You've carried out all this works over the years to help your mpg. Bit extreme isnt it :rolleyes:
:P :P :rofl:
The propane would have been having a negligible effect on the run as boost was steady around 3 psi ish at 70mph on cruise (except up slight inclines when it went to 7 or so) My propane only cuts in about 4 psi, and is regulated so is only a dribble until you get over 15+ psi. :)
As for my starts at GTI international - the only I could not have just stood there spinning the front wheels was to have bigger front tyres - or full slicks. Having traction control off meant it bogged down, so it was high revs all the way. More entertaining for the crowd anyway. ;)
When you get the full slicks you'll be gunning for that Scirroco then? ;)
I'll take it like a King! :thumbup::D
do falken do slicks??:confused:
:P
Nope, but Dunlop do - Just need to get the punctured one repaired in the next couple of weeks. Only a really tiny hole to should be repairable. :thumbup:
Have raised the suspension up higher too, so they shouldn't foul any suspension/bodywork.
