Should i change the tyre
Right guys a was dickin about in the car park and managed to knock the air out of one of my rear tyres.
I turned the car around 50 meters max but i had a car full of people whipped the spare on and got it pumped up at a local garage.
It looks ok bu obviously some of the writing on the side wall has been rubbed off but not excessively.
Will it be ok or should i change it? I did drive back from the garage with it on and it felt fine so ive left it on and again felt fine when i went to the petrol station
I'd see if it's still inflated in the morning and then decide then. Chances are it could be damaged below the amount of tyre you can see (depending on how you knocked the air out of it ;))......... If in doubt, most tyre places will whip it off and look at it for you....
Chris
Cheers chris,
Already look at a replacement and they are going for
Side wall damage could be dangerous if ignored, but it may not be as bad
as you think. Get it checked out :)
If you hit something id get the axle checked, they bend quite easily.
i didnt hit anything so i dont think i need to worry about that.
if i had done i would have just gone straight ahead and changed it.
will try and get someone to look at it tomorrow but with all thats gone off i dont know if the garage will be open at all nevermind before i go to work
