Fabia VRS - Cost of mods
Hi all,
I'm looking to get the most from my Fabia VRS & was wondering how to do it without spending rediculous amounts of money? I've been given some ideas by reading the forums but have no idea of the prices or where to get them, or whether they're in the right order?
Ideas/order so far:
1 - Jabba ARB (don't know what this is)
2 - 312mm brakes
3 - Eibach springs
4 - PD160+ intake & green panel filter
5 - Strut brace
6 - FMIC system (don't know what this is)
7 - Uprated clutch
8 - Remap
Any help would be much appreciated.
Chris
Ring Mike at Impossible Performance on 01634-710777 re the remap, brakes, springs etc.
Hi all,
Ideas/order so far:
1 - Jabba ARB (don't know what this is) This is a bar that bolts onto the rear suspension to keep the car more level around the corners - its the best mod you can do to the Fabia by far.
And yes, the order is spot on!
Might want to include an uprated turbo if you are going for the FMIC! Needn't cost the earth!
Possibly an uprated exhaust too, maybe Miltek or blueflame. :) I wouldn't go decat though imho.
I wouldn't personally bother with a strut brace and the Green panel filter is only worthwhile if you do lots of miles. Otherwise simply replace the paper element every 10k miles :D
If you're doing Eibach springs, I'd recommend investing in some uprated dampers too - either Eibach or Koni FSD (if you are feeling flush!!!)
Chris
Hi all,
Ideas/order so far:
2 - 312mm brakes
3 - Eibach springs
5 - Strut brace
7 - Uprated clutch
8 - Remap
Chris
1 - Rear Anti Roll Bar - about
How come?
How come?
:confused:
no problems with mine...... boost gauge reads a nice steady 1.5 - 1.6 bar..... I heard some say it can spool up to fast due to lack of back pressure...... when I spoke to allards about this and the affects of adding a FMIC without the uprated turbo they said it would not have any impact on the boosting etc...... going to uprate the turbo anyway though.... after the FMIC :D
Decat frees up exhaust restriction no end, even leaving the rest of the system standard. Car will breathe better - EGTs will be lower = turbo preservation. :)
thanks for the info
I was just about to say exactly the very same thing :rolleyes::D:thumbup:
Thank you for all the help.
Is the FMIC really needed as i have been told it is only really required for 220bhp+
I'd say it's needed to be able to use that power generally. You can go for arch venting and that works relatively well too. I like my FMIC, running about 200bhp according to a graph I've got, and it avoids the heatsoak.
If you run at high boost levels then a FMIC becomes more essential to keep smoke under control and/or performance at peak levels.
I used to ge heatsoak with the standard map when dropping through the gears up to around NSL already, so remapped that point is reached sooner :)
