Do you think that Jason should go 4WD or twin-engine
What should Jason do? 1 member has voted
  1. 1. What should Jason do?
    • Fit a 4 wheel drive to the mongrel
      58%
      24
    • Fit a second PD engine at the rear
      17%
      7
    • Do nothing - enough is enough!
      9%
      4
    • Return to Prague & surrender to the local authorities
      14%
      6
Please sign in or register to vote in this poll.
Thought I'd get the opinions of Briskodians. As the title say, do you think that Jason (who is ever pushing the limits of Modding) should go with a 4WD setup or should put in a second engine to power the rear wheels....
Where's the option for 6 wheel drive and two engines ? :D :confused:
4 wheel drive for me , iirc isn't a twin engined vehicle illegal on British roads
4wd for me. Just seen another pic of the rear diff setup in the gallery. :D Looks relatively easy..... :rolleyes: Seems it uses the same separate damper/spring cup setup too.
do please lemme know ;) hehe - all these options for my plans for next year :D
You're going to need more power to make 4WD worth it. Bring on the V8 fabia!
4WD all the way as i too thought that a twin engine set up was now illegal
4 wheel drive will help put the power down significantly better. Are you look at permanent 4wd or a Haldex coupling?
Chris
Chris
It'll use the same haldex setup - or at least the one in CZ did - but he had some "button" which put more power to the back wheels - Interested in knowing exactly how that worked as it seemed purely electronically setup - no mechanics involved in that. He used it for 1st and 2nd, then flicked a switch on the dash before finding 3rd....
twin engine!!!
but when did it become illegal? i remember seeing a blue vw golf twin engine a few years back with 2 G60 lumps in it and that was being used on the road
4WD from me
Then get the racelogic traction control with launch control ;)
Sat on the line at Santa Pod
Brings revs to 4k
Drops clutch
Car Flys
Bangs throught the box
Records the fastest ever 1/4 mile for a Fabia ;)
Steve
twin engine!!!
Aye you've got to disconnect one of the engines for use on the road though I've no idea how I know that.
4x4 easily.
To make the twin engine version work it'll cost more as you'd be looking at the same spec engine front and rear, both mapped exactly the same etc. You'd also need a huge ammount of bodybork mods and have to consider the extra weight.
You'd then have two options for the drive. Either the uprated haldex unit as per Eddy's car or if you fancy a challenge you could take the rear and centre diff etc. from a Subaru Justy and use that.
However, the latter may require a stronger gearbox at the front and would need the central diff.
Either will require a custom prop shaft.
ah that makes sense. i think i remember the article saying he has to bump start the rear engine after using a mech to join the gear linkage together.so it runs one engine day to day probably
twin engine!!!
Wouldnt that be Big Dub, 2x turbocharged VR6's one 2.8 and one 2.9 IIRC
Fantastic motor and a nice bit of engineering.
YouTube - Drag Race - Volkswagen Twin VR6 Turbo vs VW Golf
4WD from me
Brings revs to 4k
Drops clutch
Car Flys
Steve
given the amount of torque he'd be dumping straight onto the gearbox and the amount of traction provided, it could go more like this:
Brings revs to 4k
Drops clutch
Gears etc exit casing with a bang
Records the loudest ever "ooohhh" ever
this is going by what happened to a 4wd 1.8T on the road
:D
No brainer 4wd. If poss go Subaru type permanent system for simplicity, I also believe older Ford 4wd were permanent, XR4 & the like. Not sure what would be the most "adaptable" though, what about an older rally car transmission, Metro XR4 etc
Jason has driven with another Engine in the boot, that should give an idea of how much more the extra weight slows you down. Also keeping the rear lump cool means loads of additional air ducting
OTOH 2 engines means double the power without increasing engine or drivetrain stresses.
2 engines is just NOT happening. :rofl:
