Allard EGR blanking kit
Hey everybody!!! I've ordered the EGR blanking kit from Allard tuning. Does this make alot of difference and does it give good power gains?
Chers Joe
Does it give any power gains?
Does stop the inlet clogging up, but will put the engine management light on.
I read somewhere that EGR blanking could increase combustion temps... :(
What he said. :D
No real power gains, but it ensures a consistent, clean flow of air into the engine - which for me means clean power, and no dirty exhaust gases going back into the engine again. Management light to me means nothing, but I can scan my car when I want to ensure it's only the EGR flow fault doing it.
Is there a way of stopping the eml coming on???
Nope.
What a bugger
What a bugger
Not really. :) You just need to be able to ensure it's just the EGR bringing it up. I only worry when something other than EGR appears in 01 engine - but thankfully to date nothing has. :)
There were a couple of posts about that Alligator chiptuning (amongst others) can tune out the CEL light, but havent heard about anyone in UK doing it..
BTW - another plus is the boost gauge nipple on the Allard pipe, all ready to go....
You also get engine shut down shudder as the anti shudder valve is also removed when fitting this. You get used to it.
IS this a normal read for a car with the EGR removed?
VAG-COM Version: Release 311.2-N
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 NJ
Component: 1,9l R4 EDC G000SG 6412
Coding: 20102
Shop #: WSC 13765
5 Faults Found:
19558 - Motor for Intake Manifold Flap (V157): No Signal
P3102 - 35-00 - -
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 35-10 - - - Intermittent
19586 - EGR System Regulation Range Exceeded
P3130 - 35-10 - - - Intermittent
18009 - Relay for Supply Voltage Terminal 30 (J317): Implausible Signal
P1601 - 35-00 - -
18097 - Powertrain Data Bus: Implausible Message from Elect. Load Controller
P1689 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AH
Component: ESP 8.0 front H04 0001
Coding: 0000296
Shop #: WSC 13765
No fault code found.
Address 08 -------------------------------------------------------
Controller: 6Y0 820 045
Component: Klimaanlage X0840
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25770
Shop #: WSC 13765
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Y0 920 972 S
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 28401
Shop #: WSC 13765
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 003D GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 13765
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 60 Komfortgerát 0002
Coding: 00018
Shop #: WSC 13765
End -------------------------------------------------------
Not the last two faults in 01 no, thats something else.
This is the only one I get with my EGR removed. :)
Hmmmm, wondering about the other ones now - just keep coming back and back.
only since the EGR removal though.
P3102 - 35-00 - -
Well, these two suggest wiring loose/disconnected to me. :confused: and possibly the other two faults indirectly relate to this. Checked the plug connection on the vacuum box? Not sure where else to check.
car is running fine. strange.
Well the intake manifold flap is now missing so its not suprising its got a fault with that.
The other two are sporadic, clear them down and see how you get on.
Wonder why I'm not getting the flap codes. :confused:
Hedgehog? Did you get the full racepipe?
Maybe Allard mapped that bit out?
Possible, but I fitted the racepipe after Jabba had mapped the car on it's first hybrid, and several months before Allard got their hands on it and the latest turbo was fitted. Bit late in the night to be thinking about it, but I thought the only electrical connections to that bit of the car was the 6 wire plug going into the vacuum box. Wonder if me shoving golf tees in the two spare vacuum hose ends did anything?
It's a BLT thing as the flap is wired into the ECU, I get the first two codes too.
Aha! Bingo. But in all cases, the car runs fine it seems. :) So is there actually a spare wiring loom plug when you do the racepipe mod? Never knew that.
my car was mapped at JBS (sadly).
I had the EGR blanked at the upper pipework (the corrigated tubey bit that comes up to the OE part), which then split a few weeks later!
The whole lot is out now, and the pipework has all been rehashed. The blanking plate is now on the turbo.
Pleased with the lack of stutter, and have got sed to the shut down shudder.
Yup, I just ziptied it underneath the ECU, also had to redrill the race pipe flange as all the holes were off by about 5mm
