Octy Mk1 Bora 1.8t Same Exhaust?
I have been looking around a bit on the Ebay and as there a few more VW golfs gti's out there than Skoda's that thier parts are more plentiful and hence cheaper!
One advert i saw had a Bora 1.8t cat back stainless exhaust (which i would imagine shares the same mounting points) but this also fitted the 1.9 tdi!
Also is the Mk4 golf gti/leon cupra the same length exhaust system or is it shorter? The Octy looks longer or is it a trick of the light?
Hi i bought a full milltek on saturday
and the cat was off a leon, axle pipe from a 1.9 tdi another was a bora part
so they must all fit each other
How much did that knock you if you dont mind me asking
570 all in, but now my clutch has smoked itself to death an water pump is leaking,
its always when you spend all your hard earned too
Ouch!
Your right always the way, thats why i dont really want to replace a perfectly good exhaust until it starts blowing! Is the clutch a big job on the VRS?
the bora shares the whole same system as the mk1 octy as my milltek fits both
There is one thing you should check. Some Boras have exhaust cutouts while others do not. If you have a non-VRS you need a non-cutout exhaust from a Bora. If you have a VRS you use the cutout one.
A Golf exhaust will fit but will need modification on the rear tip/silencer since it is shorter (less rear overhang on the body).
I have a Greddy SP2 from a Jetta 1.8 non-cutout currently fitted to my 1.6 8V Octy without trouble.
