Top 5 mods for a Fabia VRS
I'm on the verge of getting a Fabia VRS and have some "spare change" to improve the car. So what are the top 5 mods?
  • Replies 97
  • Views 10.6k
1. Remap
2. Remap
3. Remap
4. Remap
5. Jabba ARB
Any more and it just gets silly :D
You can add front mounted intercoolers, coilovers LSDs etc and the money spent could be used to just buy a better car.
Jabba rear ARB
PD160 air intake
Green (or similar) filter
Remap
Seat Leon Cupra R front splitter
After those, if you have more change....
312mm TT brake upgrade
Koni FSD coilovers
Eibach springs
Limited slip differential
Then it starts to get expensive....
New turbo
Front mount intercooler
Miltec decat exhaust
another remap :D
I agree with the above comment though. No point spending £10k making a £10k better if you can afford a £20k car in the first place. For £20k I'd be running a Subaru Impreza Spec C Type RA rather than a Fabia with loads of mods which make it hard to sell and may even devalue it.
1. Remap
2. Remap
3. Remap
4. Remap
5. Jabba ARB
1. wrong
2.wrong
3.wrong
4.wrong
5.Should be at no 1
2.312mm brake conversion
3.Bettr suspension setup
4.cupra bushes
5.now you have the mods in place so your car can handle properly and is now ready for a re map:thumbup:
Remap
Green Panel Filter
PD160 Air Intake
Jabba Anti-Roll Bar
Eibach Lowering Springs
AFTER THAT:
Garrett Turbo Charger
Sachs Clutch
312mm Brakes
Then another remap!:thumbup:
Jabba rear ARB
Cupra bushes
Eibach springs
better tyres , Toyos
312mm brakes
I totally disagree
A good remap is perfectly compatable with the original parts. Dont waste time and money 'preparing' your car for a remap, just get it done! A remap will add a fair bit more oomph, but don't expect it to be a ferarri.
the pd160 intake do nearly bugger all,the sachs clutch is carp and can't handle the torque for long if you put a hybrid on,panel filter does next to bugger all,and you would run a re map without uprating the carp brakes?
You know nowt man,howmany of these suggested mods do you have?
Koni FSD coilovers
Eibach springs
KONI FSD's aren't coilovers. Hence the need for the Eibachs.
What about the top 5 with a total spend limit of £750?
I agree that it doesn't make sense to spend much on such a car.
I totally disagree
you must drive like my gran,the standard brakes on all of my fabia vrs's have been aweful,its not just prep,the standard car goes much faster with the chassis mods done than a re map alone
oh forgot tyres,lol ditch the ditchfinders
ARB, Eibachs and FSDs then ;)
I've never had a problem with the brakes on mine. I've no doubt that there are better brakes to be had but my standard setup is more than up to the job.
i would supose it depends what you do with the car,the standards are prone to fading badly on track,and i have no confidence in them due to lack of feel,but then again if an occasional back road blast is all your going to do i supose they would be adequate,the best mod on my car,that has made the biggest difference has to be the diff,i think that if i were to do it all again,it would have been my first mod,not on this budget tho:D
My bad :P
So far i've spent:
Remap - £285
Jabba RARB - £160 (second hand)
Green Filter - £35 (dosnt do much but better than the paper one)
TOTAL = £480.00
For that i have a car that has been RR'd at 173bhp, corners very well indeed and i've still maintained the original ride comfort. For me it's a fantastic every day car. It's a fun toy to play with when i fancy a blast, and it's a comortable cruiser on a long journey. what more could you ask for?
Heres my perfect mod list
312mm brakes
jabba arb
green panel and pd160 pipe
kw coilovers
decent tyres
then when you get used to lift off oversteer and the new found ability to corner at speed.
sach paddle clutch
fmic
de-cat exhaust (just hack the old one off and weld a pipe in place)
stage 2 hybrid TD
custom re-map
then when you get bored of wheelspin
peloquin atb
big injectors
another re-map
sort the handling and the brakes then go for power:thumbup:
Surely there has to be a point during where it really would be cheaper to buy a car which does it all out of the box???
Turbo, intercooler, clutch, coilovers, dampers, lsd's, uprated brakes, custom remap - you're talking thousands of pounds there, and declaring all that to your insurance company will probably add hundreds to your premium.
I agree completely. If you can improve the car significantly for under £1k then go for it, but don't expect a penny of it back come resale, in fact, expect a modified car to be harder to sell and possibly be worth less unless you can find an enthusiast who wants exactly what you've created. Mods are a good way of slowly acquiring a good car which you maybe cannot afford in a a single hit though.
i won't say what i've spent,its just not about the money for me,its about making a car that really isn't that quick,into a complete sleeper,capable of suprising cars that shouldn't be on the fabia fodder list.
I guess it depends how much you like the car your modding! ..but I wouldn't spend more on modifying a car than the cost that could be used to upgrade to another on my wanted list...
rear arb is a must-have, should have been a standard part
I just got mine last week, I have ordered a rear ARB, some koni FSD and Eibachs and probably gonna do front cupra bushes cost aprox just under a grand, but should mean I can get round the round abouts my way more like when I had my Type R, grip is worth more than power all day long. As for buying a car out of the box, yeah you could but thats just boring. imagine if all the naked woman (men for the ladies) in the world looked exactly the same, actually that might not be a bad thing if it was some bird form page 3 but I think you get my point, i think there was a point, I am off to the playboy.com
For me, the "no budget limit" 5 best mods are:
Allards Hybrid VT5 turbo
SPEC Stage 3+ clutch + flywheel
Peloquin ATB Diff
Jabba Rear ARB
Custom Remap
Sure the brakes won't be up to it, and the standard suspension will soon show its weaknesses, but it will be fun - The diff will really help. :D
Most of the top 5's ive seen dont include an uprated clutch which is madness.
Your all putting Remap as number 1 etc, etc.
To the OP, you have £750 not really enough to remap the car as you really ought to uprate other parts to cope with this power.
For you i'd say - if you want more power in the future
312mm setup (£200-300)
Eibach springs (£130) + maybe koni FSD's to go with them if you can stretch that much
PD160 intake (£60-70)
Cupra uprated Front ARB bushes (£15)
Jabbasport RARB (£200) - i dont have this but ive heard great reviews ;)
Then i would get an uprated clutch, either a Sachs if you only want 170-180bhp and if you want big power get a Helix or Spec 3 jobbie (£800-900)
Then i'd get it mapped, but even at 170bhp the Standard intercooler is at its limits, i rr'd mine at 173bhp and the SMIC was struggling (next step for me is a FMIC)
