Felicia 1.6 MPi keeps cutting out
An owner of 2 well used and appreciated cars, but one has been in hospital for a number of days and the Doctor is scrathing his head.
Problem being that my 1987 Felicia Est (102,000 miles) which was running sweetly has now started to cut out and stop for some unknown reason. The engine will run for a short legth of time, then just cuts out. The car has now had a full diagnostic check at the garage but the ECU readout shows no error codes at all. It has been suggested that the stopping is caused by a blocked fuel filter, repalced - no difference and a blocked catalytic converter - checked, no problem there.
Has anybody experienced such and knows solution/solutions, any suggestions it would be much appreciated to enable to me to get the old girl back.
Moved from Vagcom section as you have ruled diagnostics out, hopefully you'll get more exposure in here.
Is that 97 you mean?
What engine size also?
Steve,
R reg and 16. MPi
Throttle Body possibly....
250quid new...!
If not then Lambda probes are common on the AEE engine
how long does it run for before it cuts out?? a few seconds??? if so i would suggest an immobilizer fault...
failing that, try changing the fuel pump relay
Could be a whole host of things especially if it hasnt brought anything up on the diagnostic system.
Tom & Steve,
Thanks for your replies,
The car runs sweetly for possibly a couple of miles and then just cuts out as if no fuel or spark, but there is (checked RAC) or when running stationary it may go for several minutes before cutting out but will start shortly after.
yeah, i would change the fuel pump relay then
:iagree:
My prognosis is a failing coil pack
Fuel relay or coil pack; which is cheaper?
1.6 doesn't have a coilpack, it has a distributor with a single ended coil like the good old days
:)Quite common for the hall sender in the dizzy to fail intermittently IIRC.
That would be my guess also.
yeah, the o ring goes funny and allows oil to seep out from the end of the camshaft:thumbup:
oh yes it does ----part number 6NO905104
All petrol skodas since the favorit have coil packs, wether the spark is distributed by a distributor or a multipoint unit like the 1.3 mpi. Old coils went out with the estelles
erm yeah:confused:
I wasn't thinking in terms of Octy style 1 coil per cylinder coil packs; I was thinking in terms of an arangement like my ZX, which used 2 double ended coils, firing the plugs for TDC on compression to power and exhaust to intake strokes, so plucs firing once per rev, rather than each other rev. Does that make more sense now?
Thanks to all of you, you who have been so helpful with your suggestions
I have informed the 'Doctor' of your lines of thoughts and he hopefully has already ordered a new Hall sensor to try first. I will keep you informed of progress.
To all interested parties.
Doctor read your thoughts and spoke with a consultant and they jointly decided to replace the distributor. The old girl has now done over 100 miles and going as new (fingers crossed).
Thanks again for all your help and suggestions.
