Differences in Model Years 2006-2008
Skoda differences in model years.
At the weekend I picked up my new 2008 Octavia 1.9TDi Elegance Estate, trading in my 2006 Octavia 1.9TDi Elegance Estate with 20,500 miles on it. Whilst the two cars were together, and subsequently, I have noticed quite a few changes in fixtures and fittings between the two models, and I thought that I would share my findings with you all. This may be a bit anoraky (if there is such a word) but feel free to find something else to do!
The differences on the new 2008 car that I (and the wife) have noticed are:
1. The front seat pans are slightly shorter
2. The fabric (both Onyx) is different on all of the seats - softer and less rough
3. The fabric covering the door cards is different - again softer and less rough
4. The clutch is totally different - lighter and more controllable
5. The brakes are less ‘snatchy’
6. The steering wheel is smaller - but the new car does have the multi-function controls - but it is definitely smaller, nonethless.
7. The 12V socket in the luggage area doesn’t have the automatically sprung clip, but a rubberised cover - not as good as the old model.
8. The Stream radio is different in sound and functionality.
9. The front foglights are subtley different and have different lamps inside.
10. There is no manual level control for the headlights - but it does have HIDs.
11. The engine is significantly quieter - I know it is only 60 miles old at the moment.
12. The tyres are different to the ones fitted to the old car.
13. The luggage net affixments and clips are different
14. The alert noise for seatbealt non-fastening (and other things) is more pleasant (if an alert noise can be pleasant)
15. The battery is bigger in capacity (61-70AH)
16. The suspension is different, and smoother.
17. There is a warning light for the Cruise Control in the speedometer.
18. The swivelling covers for the net brackets in the boot are plastic instead of shiny Chrome plated metal.
19. The retractable load cover has a stronger spring
20. The seat belts are easier to pull out - the inertia reels are different.
21. The decals on the steering column wands are slightly different
22. The alarm beeps when it is set.
23 The material from which the keys are made is slightly different.
24. There seem to be considerable differences under the bonnet with the routing of hoses etc.
25. The floor mat affixments are different.
  • Replies 55
  • Views 4.6k
may i just enquire as to why your swapping cars?
No. 17 is on the 06 model;)
That sucks, one of the reasons I bought my Octavia were the unusually long seat squabs. I've got a 36" inside leg and the bit of extra support is nice.
I like the sound of the new clutch - mine has always been a bit smash and grab.
thats due to the xenons being a auto adjusting system, so no need for manual adjustment.
thats good to know for customers changing from older A5 to newer ones
i thought i noticed this too, but put it down to the older car a drove being, well, older :)
that is a small anoyance for me too. ive always had a light to say cruise is working
Do you have the Maxi dot? you can switch this feature on and off via that. or it can be done by VAG.COM i beleive (if you want it swtiched off :))
did yous come with mats? the latest ones ive seen now dont :(
handy points to know, thanks!
Hi folks,
Dan the V8 Man - I usually swap cars every 2-3 years, it just so happened that I got a very nice deal for mine in PX, and my monthly payments only went up by a couple of quid, so I changed slightly earlier. I was sorry to get rid of the 06 Octy; it drove very well and consistantly returned over 55 to the gallon. The new one is not doing quite so well, but it is only 125 miles old, as of today. It will improve, of that I have no doubt!
MICKVRS: On my 2006 Octavia, although you could see the symbol in the speedometer, the cruise control symbol definitely did not illuminate.
Woodenspatulas: 1) The suspension is definitely different, in that it doesn't seem to 'drop' into holes like the old one did. There is a lot less suspension 'thump' than the old car too.
2) Yes, the car came with mats
3) Yes, it does have maxi-dot.
Thanks, everyone!:thumbup:
good choice :)
I dont have an audible warning to fasten the seatbelt just a light on the dash. Am I missing something ?
erm, no it aint! :rolleyes:
yes it is!
when you activate the cruise control a symbol kinda like a mini speedo DOES
illuminate:P....jaysus:rolleyes::rolleyes:
yes it is!
Sorry to spoil your moment of triumph but you are clearly deluded............
2006MY DOES NOT HAVE THE CRUISE ILUMINATION, end of! This feature was added to 2007MY cars.
:thumbup:
It's probably been turned off - Much better IMHO.
:thumbup:
My 06 doesn't have it so I'll side with Steve.
Neither does mine :)
I'm pretty sure the Cruise Indicator was a MY07 introduction.
My September registered 56 plate had it.
...............which was a MY2007 before you get carried away again! ;)
yes it is!
It wasn't in mine, it came out sometime around May 2006 IIRC, along with other Maxidot additions, Red Calipers and the MP3 :thumbup:
One thing to bear in mind before this gets too heated - Mick's is not a UK Spec but EU spec car.
Most people are talking about UK spec cars.
MY07 from Skoda-auto.com
"Automatic activation of warning lights once the vehicle starts braking abruptly is an important innovation in the Škoda Octavia. Reacting immediately to “panic” breaking, the system activates the warning lights, thus informing other drivers of a potential danger. Other innovations include double sun visors that can be split up to two parts and a cruise control activation light situated in the analogue speedometer area.Vehicles equipped with a dashboard computer and the Maxi-DOT display offer the possibility of setting the following features individually – each door is unlocked individually and locked automatically, an acoustic alert goes off once the anti-theft system is activated, comfortable control of just the driver's window or all windows, separate (electric) control of the left and the right wing mirrors, the sunroof is shut automatically when it starts raining. The portfolio of extra items and features also includes rear seat heating now.
Starting in the Model Year 2007, the tape deck in the Melody radio system has been replaced with a CD player. Besides traditional music CDs, the new Stream radio system makes it possible to play back music CDs in the MP3 format. Useful innovations include an audio signal connection slot located in the Jumbo Box that makes it possible to connect external audio systems (such as iPOD or other types of MP3 players).
RS
The 2007 innovations in the Škoda Octavia RS and the Škoda Octavia Combi RS mainly involve the outside design – the vehicles are now available in new body colours (yellow Sprint and white Candy) and the disc brake callipers are painted red. Tinted glass in wing mirrors is now a standard part of the equipment."
Would I be right in saying the MY year in the UK starts mid year of the year before the year listed or was it just the way it happened in that case?
Model years (MY's) run approximately from July to June iirc, so for example MY2006 would run from July 2005 to June 2006, although bear in mind that old dealer stock sometimes stays in the system for quite a bit longer and may not get registered till way past this time.
I was thinking along those lines but wasn't 100% sure :thumbup:
:thumbup:
In my first post i never said anything about what month,just that was an 06 model.
If you had asked me instead of using the words 'deluded' and 'moment of triumph' I would have said.
I think Stu maybe right in saying its something to do with UK spec...I oredered mine in the last week of March and received 13/6/06.
Below,some pics(kinda crap but its difficult to take a pic whilst driving at the same time) that show my car DOES HAVE THE CRUISE ILLUMINATION!!!!!!
@VRSTU,..heated??? It is summer:rofl::rofl:
Mick:thumbup::thumbup:
You have probably got an 07 MY car Mick.
