Citigo Vagcom commands confirmed
It's been mentioned that this may be a great Sticky...a list of CONFIRMED Citigo Vagcom commands.
I did the following to my car today, a 62 Elegance 75 3dr Manual.
Go to " 09 " cent.elect.
byte 0 bit 4: auto lock at 10mph
byte 0 bit 5: single door unlock on fob
byte 12 bit 6: cornering fog lights
byte 10 bit 2: coming home drl/fog
All are great improvements to the Citigo, enhancing driving and personal safety.
I'm sure there are other things you can do to the Citigo, please feel free to list CONFIRMED commands in order to keep this easy to read!
(Please don't just cut/paste stuff from Mii or UP forums unless you personally know that it works on the Citigo!)
Enjoy! :)
  • Replies 84
  • Views 17.2k
  • Went to see my new Citigo Sport yesterday and handed them the list from the sticky post and asked them if they would enable them. They said no problem and they will all be done before pickup on Monday
  • After waiting 1hr at the Dealers I was told categorically by the Service manager that auto locking at 10mph could not be activated on my car....i came home, did some reasearch, spent a few minutes wit
  • Not sure yet about 80ish miles Might (take) you (up!) on it - no pun intended!
Can this be made a sticky please?
So this Vagcom business (can't you tell Im not very techy) how does it work? Can I do it myself for not much outlay, or pay a fortune to the dealer for them to do it?
Mick
Yeah me to
Could I take it to a dealer and get them to activate the stuff?
VCDS is a cable and some PC software that you can buy legally in most countries. The Dealer / garage uses it too to read out data from the car. Changing settings in the software lets you change what the car can do but the software is the same for all the VAG cars, so not all settings work on each car. I'm in no way an expert on this but this would be the basic functions. Search Google for 'VCDS VAG' - there are videos on Youtube too.
UPDATE: I had my dealer make mine so that the rear lights come on with the daytime running lights.
Edited by pixel_viking
Enjoy! :)
Got my dealer to to the Cornering Fog lamps mod... (he was impressed that i gave him the VAGCOM codes) it was done when i arrived to collect my new citigo today. I guess it depends on the dealer, Ive found a fantastic guy at my local. couldnt be any more helpful and genuine! now the fun begins lighting up side streets and driveways on arrival. thanks for the tip @estorilblue
nb! sorry, repeat post... i put this in the wrong topic. should have been over at the cornering fog lights. my bad!
Edited by andy0681
Enjoy! :)
Sorry but whats the top command do?
Do you mean 'Go to " 09 " cent.elect.' ??
If so this is the heading of the software category where you make the changes.
If you mean 'byte 0 bit 4: auto lock at 10mph' - this locks the doors when travelling above 10mph :)
If so this is the heading of the software category where you make the changes. - This one, so they all start with this bit?
Could you please write down your VCDS version and BCM PQ unit code. I couldn't enable cornering fogs it just says request out of range.
Saturday,02,February,2013,21:44:40:22041
VCDS Version: Release
11.11.5
Data version: 20121222
Address 09: Cent. Elect. (J519) Labels: 1S0-937-08x-09.clb
Part No SW: 1S0 937 090 HW:
1S0 937 090
Component: PQ25 BCM H57 0555
Revision: -8------ Serial number: --------------
Coding: 64B8290000010000000009F42E28ACD077C0426F7E820440200000420100
Shop #: WSC 31414 790 00001
VCID: F0E4E53723F58A9851C
No fault code found.
(This was before any coding was changed)
Thank you very much. Could you please send the Coding after changed. I have exactly the same BCM unit so I can confirm that I have to update my cable
Part No SW: 1S0 937 090 HW: 1S0 937 090
Coding: 7CB8290000010000000009F46E28BCD077C0426F7E820440200000420100
Shop #: WSC 73430 790 00088
I activated the anti hi-jack (auto lock) and auto unlock as well as the cornering fogs,
What VCDS release are you using?
Friday,08,February,2013,21:23:36:10074
VCDS Version: Release 10.6.4 (x64)
Address 09: Cent. Elect. Labels: None
Control Module Part Number: 1S0 937 087 B HW: 1S0 937 087 B
Component and/or Version: PQ25 BCM H28 0555
Software Coding: 74B82B000001000008000C042C28BCC00040400C60060400200000420100
Work Shop Code: WSC 31414 790 00001
VCID: 387B2CD332C3
This is my default coding, I think I have a stripped BCM :( It is an Elegance 44KW ASG
Edited by rumiexile
Not surprising really your VCDS software predates the Citigo, update the software and try again. Mind you your CCM is different as well.
That is assuming you are not using hacked software?
Does the single door unlock on fob work the same way as other Skoda's.
1st press = drivers door unlock then a 2nd press just after to unlock the other doors?
Has anyone checked to see if you can enable or is it already enabled the hold the lock or unlock remote button the electric windows will close or open?
1 click = drivers door, 2 click = passenger door.
I have been informed that the Citigo won't undo windows (and reverse of this) by holding fob buttons as it doesn't have the physical equipment needed to do this. I also attempted to program this via vagcom to check and it didn't work so I guess it can't be done? (Please prove me wrong as I'd like this feature myself!)
Well I have requested the following setting from my dealer. hopefully FOC with the car and extras i'm buying (mudflaps F&R, rear bumper protector, sill protectors, extra folding key, nets and raised boot floor) but if they don't or want a fortune I may be calling a local member that can? Beer anyone?
I'll have a go at seeing what I can activate when I get mine. Though fairly new to VAGCOM
I personally don't have access to VCDS/Vagcom. but would be interested in getting it. What is the best way and how much? It would need to be compatible with my 07 plate Ocky?
VCDS is approx £250 (from NHN)
Alternatively you could contact a local Briskoda VCDS owner from the list / map in my signature..
Cheers for the info
£250 is a little out if my league at the moment.so pending on how the dealer does I will contact a local member for assistance.
Edited by Owens
Yep got mine booked in for Thursday as they had a look on Saturday and couldnt do it then - but instead stopped the 1 touch wiper thing
Having cornering fogs & coming home lights
...UPDATE: I had my dealer make mine so that the rear lights come on with the daytime running lights.
Hallo pixel_viking,
This feature I have tried to set my Citigo without success so far. Do You have any idea or more details what byte(s)/bit(s) Your dealer have changed?
BR
- Litti
Hallo pixel_viking,
BR
- Litti
Sorry, I don't have that info. Maybe I can find it in the Danish forums, where I read about VCDS.
