Fabia 1.4 no spark
Recommended Posts
Hi All
I have a 2006 Fabia 1.4 petrol. Having been driving perfectly it suddenly stopped and has not run since. We have looked at the codes which suggest crankshaft sensor and ignition secondary circuit. We have changed the crankshaft sensor but its made no difference there is still no spark.
We checked the connections to the crank sensor and one of them shows 5v when the ignition is switched on
Any ideas fellas?
Link to comment
Share on other sites
Suggests that sensor itself has gone or the wiring to the sensor. Don't have a wiring diagram for Skodas but you should be able to find out which is GND, you seem to know which is 5V and the third will be the signal. Using an LED with appropriate resistor in line you can do an easy check to see if it's the sensor itself or the wiring.
Also does VCDS spit out any errors?
Link to comment
Thanks guys
sorry to be really thick but how to I use an led to test this. I know which is +5 and can find which is gnd. I know how to make an led light with resistor but i'm afraid im from the era of minis and rwd escorts. Also not sure what a VCDS is
Oh dear sorry guys
Link to comment
Why not try another coil pack? Get a cheap used one. Good to have anyway. I have a pack under the driver seat... Paid about 50 pound..
Edited by Torbo
Link to comment
What sort of sensor did you buy, its not beyond the realms of possibility that the new sensor is faulty, if you follow Techie's advice it will confirm this
Edited by SuperbTWM
Link to comment
Thanks guys
Oh dear sorry guys
You can test the output from a hall effect device (crank sensor) using the AC volts setting on a multimeter, you should get ~0.5V AC between signal and ground while cranking the engine. Make sure the new sensor is mounted flush and you haven't left it proud at all otherwise it won't pick up the signal from the crank, the tip of the sensor should almost be touching the trigger wheel.
Link to comment
If there is no crank signal a coil pack will make no difference.
Does he have a crank-signal?
Link to comment
Hi all
The saga continues........
We have rerplaced the crank sensor again and we now get a signal and the rev counter moves when cranking but it still wont start. We have re-read the codes and are now getting a P0353 code which is the coil pack on no.3 cylinder. Replaced the coil pack still nothing.
No. 3 coil pack has 2 brown wires which appear to be earths a thin purple wire and a thicker purple and Black wire. I only have a multimeter and on cranking the 2 purple wires do nothing on AC setting and show a small fluctuating voltage on DC
Lost me im afraid
Link to comment
A coil pack down won't stop it running, it would just misfire.
P0353 is an electrical fault on the coil. Assuming the plug is ok and swapping the coil pack to another cylinder does nothing then there is a chance whatever wiring fault you have is also effecting the other coils. Looking at the crank sensor issue and how that is resolved now I am wondering if that has been cured by the sensor of my moving wiring in that area. Be a good place to start looking.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
