Flashing glow plug warning light - Should I worry?
  • Please log in to reply
19 replies to this topic
#1 patrickd
patrickd
    Briskodian
  • Members
  • Pip
  • 28 posts
Posted 09 April 2007 - 12:13
Hello,
The glow plug light on my dash has started to flash on and off while I'm driving. Does anyone know what this means?
The car (a fabia SDI) still starts alright and runs ok so I assume they don't need changing.
I'm about to make a long trip and a bit worried it could be serious.
I'd be very grateful for any advice
#2 Td-eye
Td-eye
    Briskodian
  • Members
  • PipPipPipPip
  • 622 posts
  • Car:Fabia 1.9TDI Elegance Estate 140 BHP & Golf 1.9Tdi 180 BHP both remapped by Angel Tuning
Posted 09 April 2007 - 12:24
Probably a bulb out, check all lights including brake lights. :)
#3 johnjohnhealy
johnjohnhealy
    Briskodian
  • Members
  • PipPipPipPipPip
  • 2,433 posts
  • Car:Impreza/Galaxy
Posted 09 April 2007 - 13:16
I think it normally means the brake light switch is broken, check if the brake lights work!
#4 UncleBuck
UncleBuck
    Briskodian
  • Members
  • Pip
  • 31 posts
  • Car:Fabia vRS
Posted 09 April 2007 - 14:40
Brake lights will be on constantly mate. You will need a new switch.
Use 1J0945511D up to chassis no 6Y-3-725552 or 3B0945511D if a later chassis no. Part no. changes again in 06 model year. Best get your dealer to check for you. :thumbup:
#5 Td-eye
Td-eye
    Briskodian
  • Members
  • PipPipPipPip
  • 622 posts
Posted 09 April 2007 - 15:52
It could be either the brake light bulb or the switch that causes this fault. Brake switch failure is quite common and there is an updated (purple) switch part number 1J0 945 511 F which supercedes 1J0 945 511 D see:
Fabia-vrs.com - Brake Pedal Switches :thumbup:
#6 patrickd
patrickd
    Briskodian
  • Members
  • Pip
  • 28 posts
Posted 09 April 2007 - 21:32
Many thanks for all the responses.
I'll check the brake lights.
Assuming the brake lights are uneffected, can I do any harm driving the car with this light flashing away??
thanks again
#7 Td-eye
Td-eye
    Briskodian
  • Members
  • PipPipPipPip
  • 622 posts
Posted 10 April 2007 - 04:52
Well, it's flashing for a reason so you really should get it checked out.
It should have thrown up a fault code so I'd go to the dealers and get the code read if it's not the bulb/ brake switch. :)
#8 Mattcooper79
Mattcooper79
    Briskodian
  • Members
  • PipPipPip
  • 471 posts
Posted 09 July 2007 - 19:26
The Glow plug light started flashing on the way home tonight. I assume its the brake switch as non of the rear brake bulbs have blown.
Is it a problem to drive the car for a couple of hundred miles until the dealer can change the switch.
Matt
#9 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • PipPipPipPipPipPipPipPip
  • 35,856 posts
  • Car:Fabia Saloon 20vt, Citroen Motor Caravan
Posted 09 July 2007 - 19:28
Depends on if your lights are working.
#10 Mattcooper79
Mattcooper79
    Briskodian
  • Members
  • PipPipPip
  • 471 posts
Posted 09 July 2007 - 21:06
Yeh just went and checked again and i have no brake lights at all, so it will need attention asap i think.
#11 flands
flands
    Briskodian
  • Members
  • PipPip
  • 89 posts
  • Car:Fabia VRS
Posted 11 December 2008 - 09:43
Same thing has happened to me, On the weekend the flashing symbol popped up on the dash and only by finding this thread I worked out what it was, So a BIG thanks! saved me a few quid by avoiding booking it in at the stealers.
#12 dfullb
dfullb
    Briskodian
  • Members
  • PipPipPipPip
  • 756 posts
Posted 11 December 2008 - 21:29
Best do, before Someone Rodgers your Rear :eek:
Dean
#13 bobjim
bobjim
    Briskodian
  • Members
  • PipPipPipPip
  • 702 posts
Posted 11 December 2008 - 21:54
Dean
i would hope he has done something about it by now in the 17 months gone by!!!!! :rofl:
#14 dfullb
dfullb
    Briskodian
  • Members
  • PipPipPipPip
  • 756 posts
Posted 11 December 2008 - 21:57
Blimey, Never looked at the Original Post date, Just the last !!!:rofl:
Unless of course he likes his rear rodgered !!!:D
Dean
#15 JP1 VRS
JP1 VRS
    Briskodian
  • Members
  • PipPip
  • 98 posts
Posted 12 December 2008 - 09:26
This happened to mine after braking hard stopped doing it after a while and not at all now ,my coolant level light comes on also when its proper cold in the morning but run the car for 5 mins turn off and re-start it goes away ,this along with the washer fluid level and fuel level warnings is just another f'#$king beep
#16 Sonic_Vrs
Sonic_Vrs
    Briskodian
  • Members
  • PipPipPipPipPip
  • 1,916 posts
  • Car:Octavia 2.0 TFSI vRS Shark'd
Posted 12 December 2008 - 14:57
Exactly the same as me. coil light came on, blinked for a journey and then disappeared.
The cold start 'coolant' light comes on minetoo. Bloody loud and annoying @ 5:30am...
#17 ap0gee1978
ap0gee1978
    Now with added vintage.
  • Honorary
  • 10,481 posts
Posted 12 December 2008 - 15:03
I can sell you a 'repair box' for a very reasonable price... ;) :D
#18 kingcarp69
kingcarp69
    Briskodian
  • Members
  • Pip
  • 12 posts
  • Car:octavia estate 1.9td (04 plate)
Posted 23 March 2009 - 13:23
huge thanks to those who said check bulbs, coil light was flashing so checked bulbs. Both were out, changed bulbs no flashing light now. Saving me lots of time and money at a Skoda dealer, lol
#19 VRSBUZZ
VRSBUZZ
    Briskodian
  • Members
  • PipPipPip
  • 174 posts
Posted 02 October 2009 - 20:36
My Fabia Elegance 1.9Tdi had this flashing glow plug light problem intermittantly. The new switch for mine was a genuine part heavily modified but not in the purple colour as indicated above. Do not worry if it is not purple as it should still cure the fault. I dismantled the old switch to find that there had been an amount of arching between the points of the switch casuing pitting to the electrodes.
#20 rum4mo
rum4mo
    Briskodian
  • Members
  • PipPipPipPipPip
  • 3,697 posts
  • Car:B8 S4 3.0TFSI + 6R C0 Polo 1.2TSI 110 + 6J Ibiza 1.4 SC
Posted 02 October 2009 - 21:00
Out of interest, what is the current colour and p/n for this switch (I had to change mine a few years ago - think I ended up with a purple one).
