Everything posted by TMB
- Skoda Fabia MK1 End of life??
Skoda Fabia 2004 battery drain
It's very easy to remove the instrument cluster. I would try taking the two plugs and and off a few times and then spraying the cluster pins and plugs with contact cleaner spray. From my own experience I have found the cluster plug connections to be a bit fussy. There's also the possiblity of dry solder joints inside the cluster but I would try the plugs first. Why the battery is draining I don't know, though. I would clean that earth up too. This video is about the immobiliser but shows how to pull the cluster out and remove the plugs. For 20 mins work you have nothing to lose...
Help buying spare fuses for Fabia Mk1 (and cheap bulb / fuse "kits")
Yes, those are correct for the brake and reverse
Bonnet won't close / lock / latch
- Bonnet won't close / lock / latch
I can see that your catch mechanism is stuck and needs freeing off, and/or the return spring may be broken (unlikely but you never know). On yours, the black bit in the orange circle is stuck back from the cable end... A pic of mine showing cable end in contact...- Bonnet won't close / lock / latch
- Immobiliser issue
https://www.briskoda.net/forums/topic/369663-yet-another-fabia-immobilizer-thread-solution-included/- Immobiliser issue
Before you bought all that stuff did you check the immobiliser solder joints inside the cluster? Very common issue...- Help buying spare fuses for Fabia Mk1 (and cheap bulb / fuse "kits")
That second kit (and possibly the first kit) doesn't have the correct tail light bulbs. The Fabia uses 566 offset pin tail bulbs which are twin filament 21/4 watt. One filament sevrves as the tail lights and one the driver's side fog light. The left fog filament is redundant. The number plate bulbs are also wrong in that kit (should be 239). No correct indicator orange bulbs either (should be 581). The kit also does not contain a H3 main beam bulb. Some of the Fabia's fuses are mini blade fuses and those kits look to only have standard size blade fuses. Brake light bulbs are P21W (382).- SOLVED: Fabia cranks but won't start - sometimes!
You mentioned a compression test - did you do one and if you did what were the results?- Some bare wires and bad connectors in poor conditions
Error- Some bare wires and bad connectors in poor conditions
Are you going to fix the cut wire too?....- Some bare wires and bad connectors in poor conditions
^ Excellent!- Some bare wires and bad connectors in poor conditions
Yeah, the PAS pump might be cycling on and off for some reason. The on and off load on the alternator would affect the idle.- Some bare wires and bad connectors in poor conditions
What if you tried running the engine without the aux belt on so that the alternator is not turning and see if it makes any difference to the idle?- Skoda Fabia MK1 End of life??
OK, well here's a copy and paste of the solution...- Some bare wires and bad connectors in poor conditions
No problem- Some bare wires and bad connectors in poor conditions
OK. - Bonnet won't close / lock / latch
