Everything posted by TMB
non starting problem (Earths)
Yes that is correct.
Mk1 fabia radio
Another member of the tinnitus club here.
Probably going to be saying goodbye unless there's a cheap Scala or similar nearby.....
Wow, I have a 3 cylinder Peugeot 107 and you can hardly tell it only has 3 pots, pretty smooth.
Skoda fabia heater resistor
Loads of resistors on ebay. I bought one from there that lasted the whole ten years I had the car and was still going when I sold it. One thing that does kill them is letting the cabin filter get too clogged up. Take your pick... https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p3519243.m570.l1313&_nkw=skoda+fabia+heater+resistor&_sacat=0
Just ignore his use of the wrong word ''sensor''. It's just a resistor.
Fabia VRS AUX/Drive Belt Replacement How to?
Huh?
2006 fabia estate
Same thing happened to me. Phone and keys locked in the car and engine still running. Broke front passenger window. Cleaning all the glass crystals up was not much fun at all. Ebayer sent me a tinted window instead of the clear one I ordered but you could hardly tell once it was installed. Waiting for window....
Engine jolting sharply when releasing the gas pedal
The whole clutch pedal on my Mk1 Fabia was made of plastic. I thought they all were.
Strange pattern on inside of headlight lens MK1 vrs
Tungsten.
Slight uneven drop in revs at Idle on VRS
https://www.ebay.co.uk/itm/275524708777?hash=item
Changing drivebelt easy?
Hehe, yours looks more logical, tbh 👍
Hmmm, wonder if the belt is installed wrongly on the one in my pic.
Are AZQ & BME meant to be the same?
EDIT: Ignore the following pic - belt has been installed incorrectly. Here's a handy pic (assuming it has A/C?).....
Skoda Fabia 1.4 mpi Rough Idle, Seems like it wants to stall.
No problem.
Also, MinkyMike hasn't been online here since December 2021.
This is impossible since the 1.4 mpi 8 valve has a single coil pack unit for all four cylinders. If yours has 4 coil packs it can't be a 1.4 mpi 8 valve.
VRs gearbox issues
- AnnoyingPentium's 2006 Fabia 1.2 12v Ambiente-ish
Only 26,600 miles on the Vectra according to the MOT history, or has it been round the clock? Also, like the way the last three letters of the registration are three letters in ANnoying PentiuM 😁- Both front windows not working from any switch?
.............- Both front windows not working from any switch?
..............- Trip counter mystery
These are the two trip buttons that get pressed when you turn the trip knob left or right. It's possible that one of the buttons is stuck/faulty....- Front brake caliper rattle problem
I'm sure there's sometimes a bush for the pins inside the rubbers? I remember seeing nylon type ones on some cars.- Anti roll bar bushings questions?
Fair enough. I just do them by feel anyway.- Exhaust help!
You can get a little Chinese electronic box that makes the owl noise every time you lift off the throttle 😆 - AnnoyingPentium's 2006 Fabia 1.2 12v Ambiente-ish
