Everything posted by cnc
TPMS Management
I find on my Superb it's pretty sensitive, I recently got a warning saying one of the tyres had low pressure, upon checking it was only 2psi down from the other three, I would consider that reasonably accurate, pretty close parameter wise (based on wheel rotation - I don't have the active TPMS). Having said that I would consider having the direct system option on my next car if it's not standard (depending on the option price), currently £155 on the new Superb.
Alas its goodbye
Good to hear the Superb served you well, I hope the Audi EV serves you just as well 👋
Cambelt and water pump - dealer vs independent
Go with the main dealer for peace of mind, having mine done next week at Skoda for £807.
Crack has appeared in heated windscreen
According to the Skoda UK warranty terms & conditions the windscreen is covered for the first month or 600 miles from date of first registration (whichever comes first), https://www.skoda.co.uk/_doc/190724ab-ac7d-4c6b-943a-c80462816d1c
Had this on the wife's Octavia, parked it on the drive one evening, got in the next morning to find it cracked just as in your picture. The very bottom of the windscreen is covered by trim but it did appear to originate from the lower edge upwards. Stress fractures can happen unfortunately, in our case there was no warranty on the car so we had to pay for a new screen. Hope your dealer helps out in this instance - fingers crossed.
Skoda online store hacked
Air Care won't activate
Maybe try the coding here near the end of the thread kindly posted by SasahGrace, although the coding is to have it on permanently - worth a try?
intermittent gearbox malfunction warning while driving
Do you get the 'Error' message briefly on the dash, if so take a look here:
That price seems very reasonable (to a diesel driver), works out at about £1.545/litre - imagine how us diesel drivers feel, I saw some this morning at over £2.00/litre, but generally around the £1.90/litre, the same 66 litres would be over £125 (although my average economy is pretty good which partly goes towards cancelling the higher price out- luckily).
2016 Superb 2.0Tdi burning oil
It's odd how some engines use oil and some don't, with greatly varying degrees of oil consumption. I've been checking the oil level on my 2.0TDI more regularly lately, not because it's using oil, but because it isn't! (just making sure). The more miles I put on it the less it uses, now 3 1/5 years old just coming up to 124k, but it does have an easy life sitting on the motorway at 70mph (1600rpm) for mile after mile. An added bonus this morning was I covered 225 miles with an average consumption of 74.3mpg.
- More buying info
- More buying info
More buying info
This Skoda UK page suggests the battery is under warranty for 8 years or up to 100k miles whichever comes first, no mention of number of owners. However, it does state the warranty is for battery 'defects' , which is not the same as if the battery was to not last 8 years or 100k miles due to its natural life span- clarification from Skoda would be required as it's not clear in my mind. Electric Car Battery & Lifespan Guide | Škoda UKLearn how electric car batteries work, how long they last and what they are made from. Discover lifespan, replacement costs and charging essentials.
More buying info
Features such as some of the above were optional when new, unless you buy a top spec version to begin with, and even then they don't include all the features your Freelander has, it's how Skoda make the entry price appear attractive, but when you have added all the features you really want the price becomes rather more than you initially thought. That's sales! If you are lucky you may find a second hand one where someone added all the features you list when new. Will your budget stretch to a Superb iV plug in hybrid, if so the L&K version may be worth a look as it has everything you list plus more, or an SEL with added winter pack.
- More buying info
More buying info
I believe the Octavia PHEV was only available from 2021 to 2024, so all will be the mk4 version, all have the small(ish) 13kWh battery, officially giving up to just over a 40 mile range, in reality nearer 25-30 mile range, and with only one gearbox as stated by Evolution13 above. When the mk4.5 (facelift) was introduced in 2025 the PHEV was discontinued in favour of the MHEV version (1.5TSI e-TEC which is not plug in). The PHEV has a raised boot floor height to accommodate the battery and there is room for a charging cable underneath but not much else. You could have a spare wheel and store it in the boot using the tie down points to keep it in place. Some have managed to get a space saver (skinny) spare to fit under the boot floor but not ideal. However, as you may not be in the UK the information above may be different in other countries. Pretty sure I've got that correct, happy to be corrected by anyone with greater knowledge than myself.
Kodiaq 2025 2 litre petrol economy
13L/100km is 18 US mpg, in UK mpg that's about 22mpg which sounds about right for the 2.0 TSI in city driving.
Should I swap for 1.8tsi? any good engine
The wife has a 1.4 TSI DSG Octavia FL and it's a great engine, more than quick enough when needed, but also economical when driven gently, often returning 50mpg+, I would have no hesitation in recommending this engine. I have no experience of the 1.8 TSI but have heard 2013 and older versions can consume lots of oil, later ones are better, hopefully someone a bit more knowledgeable than myself may be able to clarify the 1.8 strong/weak points.
This afternoon the Superb had it's third replacement windscreen, so on the fourth windscreen in total if you include the original. It's now 3 1/2 years old with 120k on it and it spends lots of time on the motorway, so anything that gets thrown up off the road in front generally hits fairly hard at motorway speeds. Apart from that it's running great, the fuel consumption is starting to get better with the warmer temperatures, oil consumption is negligible, also just filled up the Adblue with roughly 15 litres, enough for about the next 20k miles.
Screenwash usage
I cover about 3k miles a month and over the winter period I probably refill it once every two weeks, this is usually before the low warning light comes on, but about 5 litres a month as a rough guide for me. Usage very much depends upon if you give a short or extended wash, I also give the rear screen a short wash just before I put it into reverse, not because the rear screen is dirty (I have a hatch) but it washes the rear camera at the same time.
Panoramic sunroof rust
Could this be covered by the 12 year corrosion warranty? The warranty covers rusting from the inside out' and it does appear to be rusting from inside the seal, not from the outside inwards. Might be worth asking your local dealer.
- Remove Enyaq Tailgate Interior trim
Guess the Hire Car.... Mac's 2019 game
Toyota Aygo X (and no, the X is not a kiss..........)
Heated front screen option?
VED and Car List Price
The simple answer is no! Firstly they can purchase the car at dealer rates from Skoda UK, and provided they sell it withing 12 months can also claim back the VAT which at the current rate of 20% is quite a lot https://www.gov.uk/vat-motor-dealers
