1.3 MPI Pickup from 2000 - customer lost his only key
The code is: 1H0953257B https://webautocats.com/etka/skoda/fel/101/953600/ To buy it as new the price is astronomical ! 😲
The code on the module helps? In the other end of the ring isn't the modul attached?
https://www.youtube.com/watch?v=P0gVqlekVSw
Felicia Combi 1.3 - what oil?
You had in the past oil leaks with the 15W-50?
Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman95456 Km (155,3 in the Trip meter) so the distance was 81 Km in Mountain Roads. Keep in mind that the car had: 2 persons, 2 valises, 3 sport bags and a 3/4 full tank in a hot sumemr day. The Total consumption is 9,4 litres which is Average 6,06 ltr/Km or 46.61 British MPG (Excellent result) 🤩 The Ø indication in the TC-6 agrees.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI can not rely 100% on the factory cluster gauge but on the other hand the aftermarket on the central console isn't something expensive as a GReddy or AEM.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe car is off, below the digital meter says 13,13 volt.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanRefuelling, TC-6 is zeroing and the trip begins, Odometer indication is 95301 Km (324,8 in the Trip meter), at the first stop: Now the Odometer indication is 95375 Km (74,8 in the Trip meter), the distance was 74 Km in Highway and the Total consumption is 4.4 litres which is Average 5.94 ltr/Km or 47.56 British MPG. The Ø indication on the TC-6 agrees. Keep in mind that the car had: 2 persons, 2 valises, 3 sport bags and a full fuel tank so with that weight i find the Fuel Consumption that hot summer day as Very Good. The next measurement is after a Mountain Route (lot of curbs in an uphill and then downhill) till final destination at noon.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAn unofficial comparison of what the cluster gauge shows and what the aftermarket in the console (it's sensor is after the expansion tank's hose to the radiator). and The photos are taken immediately when i stopped the car. As you can see they don't match.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanApology: i have done a mistake in posting, i forgot to mention that from the point of 94969 Km i have changed the G12 Plus with the good-old G12 so any MPG results from this point https://www.briskoda.net/forums/topic/512393-cooling-system-problem-again-in-my-felicia/page/3 till today are with G12, so any comparisons from now on are: G12 HEPU and old radiator vs G12 HEPU and new radiator. So i had: 95297 Km and i had 21 litres which means from the 94976 Km i have travelled 321 Km distance (according to the Trip meter is 321,1) the Total fuel consumption was 6,54 ltr/km or 43.19 British MPG and the trip begins, after refuelling the Odometer indication is 95301 Km (324,8 in the Trip meter) Total consumption 21.5 litres and Average is 6.6 (or 42.80 British MPG). The next measurement was in 95375 Km, i have also manage to take photos from the highest point of coolant temperature at 95640 Km and i will compare it with the indication of the console thermometer. (to be continued)
Felicia Radiator Stalling Theorem
If you can design a different type of fan blades or install a most powerful fan from another model then go for it. I have opened in the past a topic about an auxiliary electric fan. I think my contribution in this topic ended...
I remembered these: "It's a liquid cooled engine. Cooling the engine bay doesn't do much. "Felicia has a big hole under the engine, I could feel hot air coming out of the engine underneath and the car - and that was with the weak motor of the non-ac 1.3. With AC, you have two speed fan, if it's not kicking to second speed, you have plenty of cooling."
Skoda pickup 1.6 cubevan
D.FYLAKTOS replied to sparticus-84's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSkoda Felia 1.6 AEE 75Hp brake pads https://kritosparts.gr/SKODA-FELICIA-I-Pickup-(6UF-6U7)-10-95-04-02-1.6-AEE-(75hp)-06-97-04-02/Takakia-set/m106_a3994_t8702_r402_v2 Click the i for each one to see the dimensions.
I have posted in the past photos of mine (with A/C) there is no space to fit a larger radiator (ftom th 1,6) because the aircondition pipes are obstructing the fitting.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI am on vacations, new measurements and photos soon. I will make a comparison betwwen the gauge indication and the console (coolant) thermometer, snapshots from the highest gauge indication plus fuel comparison measurements.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYou had 78-87 'C and now installed 85-92 'C?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYes, i have said that in the past https://www.briskoda.net/forums/topic/491645-can-i-make-a-modification-to-my-felicia-13-filter-case https://www.briskoda.net/forums/topic/526164-question-felicia-13-mpi-alex-hvac plus the story of the owner (is in israel) because one of the Skoda mechanics from the official dealership (where i bought the car) had travelled there for a/c seminar-tour in the factory etc. Your radiator switch is 80-85,85-90,90-95 'C ?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAt Green dot and extremele rare. https://www.briskoda.net/forums/topic/512393-cooling-system-problem-again-in-my-felicia/page/4/#findComment-5950995 Mahle with 2, here is an example: https://i.ebayimg.com/images/g/NPMAAOSwl7Fm6yfy/s-l400.jpg i never had 3 prone in my Felicia, never saw one in the market.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have a/c and two speed radiator fan.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSo what's next? We must change the radiator switch to 85-90 or 90-95 'C? If i remember correct the factory in mine was 87-92 'C.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSince we didn't clarify what was the ''BTB'' that @Thefeliciahacker use... But you had that problems few years ago. So what's next? We must change the radiator switch to 85-90 'C? If i remember correct the factory in mine was 87-92 'C.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanGoogle search: BTB test stands for bovine tuberculosis test.
Drive with me and with my Sport Line
The next video will be in a Mountain road?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI don't think that anyone has an 80 'C thermostat, those for Felicia in the market are 87-88 'C. An example: https://kritosparts.gr/SKODA-FELICIA-II-(6U1)-01-98-06-01-1.3-AMH-(68hp)-01-98-06-01/Thermostatis
Fuel smell in cabin felicia pickup
D.FYLAKTOS replied to sparticus-84's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanInside has this https://ae01.alicdn.com/kf/HTB1iY6aLpXXXXcRXXXXq6xXFXX can be replaced? At 1:43 says it clear, Fuel Smell.
