Brake System Maintenance Question
Strenghts: 1) It has a high boiling point since it does not absorb water. Therefore, there's no so-called wet boiling point. 2) Doesn't absorb moisture. 3) Doesn't remove paint. 4) The viscosity is more stable over the extremes of temperature. 5) With the exception of some formulations used in external boots, silicone brake fluid is compatible with all standard brake components. Drawbacks: 1) It's hard to pour without entraining air bubbles-hence an application will generally have a softer, spongier pedal feel. 2) It doesn't absorb water, so any water already in the system accu-mulates in the lowest point of the system and stays there, causing rust. 3) Glycol fluids begin to compress near their boiling points, whereas silicone fluids begin to compress at around 300-350 degrees Fahrenheit. 4) Additives in the fluid can vaporize at comparatively moderate temperature, increasing the spongy feel. 5) Silicone fluids expand significantly when hot. 6) Silicone fluid is functionally incompatible with systems that have held glycol-based fluids for any length of time, requiring flushing and seal replacement (there are counter opinions on this, which state that the modern silicone formulations are in fact compatible with only a flushing, rather than a complete reseal). The actual DOT specification requires chemical compatibility, so as far as that goes, the two fluids won't cause reactions if used in the same system, but they certainly won't mix, either. 7) It's pretty much incompatible with anti-lock brakes because the silicone fluids tend to be more viscous, which can cause problems with the timing of the pulses that are intended to work with the thinner glycol-base fluid. This sometimes leads to damage of the ABS valving. The rapid pulsing necessary to anti-lock functions tend to cavitate the fluid, as the tiny bubbles collapse and coalesce into larger ones, and then collapse and reform into smaller ones. This tends to counteract the ABS effect and can diminish the actual effective braking. This condition also heats the fluid and can lead to even more sponginess and possible damage to the ABS controller. Thirdly, silicone brake fluid tends to foam when expressed from a small orifice under pressure, reducing its hydraulic effectiveness greatly. https://www.jalopyjournal.com/forum/threads/whats-the-negative-of-silicone-dot-5-brake-fluid.185724/
Few months back i changed the brake fluid, one mechanic insisted that the systhem ''pump-start draw of old fluid-simultaneously add new fluid-after a while the whole system has the new fluid with no bubbles'' is ''new'' and ''better'' than other ways. I never convinced that this kind of flow can remove any remains of air from all the system. I said ''NO'' and i left, i went to another giving him strictly orders to do the change with ''Old fashion way'' which means 2 person, one is pressing many times the pedal and the other degassing etc.
I am not sure that @R_Blue has car with ABS Model: Škoda Forman LX - W/LPG Year: 1993 I have seen it in the Army, the previous driver (soldier) mixed Hydraulic oil (red colour) with other and the final result was something like beige. Every NCO was pointed this to us plus everybody cursed that soldier for what he has done. The door was working but it was a matter of time before they ''flush'' that mix and replace it wirh the proper (because everybody knows the concequenses if something is broke). DOT 4, DOT4 racing, DOT5.1 yes but DOT5 for us here means ''Military'' mainly https://dot5brakefluid.com and not every day use for moder cars.
I wouldn't take that risk, the Dot 5 must not mixed with Dot 4. Can you "flush out" perfectly the whole system from Dot 4 before you turn to Dot 5? I wouldn't make my Felicia as "test animal" just to save some money from brake fluids changes. Is there a quarantee that your Dot 5 will last as long as you have your car? I am saying that because i have heard about "lifetime" and "no need to change them" steering wheel fluids even for coolants.
Are made from Brass?
Need quater panel
D.FYLAKTOS replied to Seanconsidne's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanA relative thread about a pickup restoration in the same area.
Heating Problem
If it's a warm day, high rpm for long time, load in car etc so what's the problem for the radiator to work for at least 45 seconds for few times when the temperature is 95 'C ? This shows that the engine is ''pushed'' a bit. The bad thing is when the radiator works for may minutes without stopping.
You could paint the calipers with another ''fancy look'' colour (heat resistance). They look good with the (aluminium colour) rims.
Skoda Felicia Speedo problem
Some times my english don't help me, for sure it has as i show it. It happened to me few years back, i had a ''squeaky noise'' in national way only, not in city roads. The problem was on the base of the square wire, by mistake i had put in the past some silicone oil inside the ''nest'' and in high rpm the wire was trembling. Another time that white (like Teflon) clip wasn't secured 100% (it's twist and click procedure) and i had a noise that something was ''coordinated'' but when i removed the panel both of these problems solved.
Heating Problem
Coolant level is OK? Have your mechanic made a ''pressure test'' to see any leaks?
Favorit/Felicia Front and Rear Brakes - UPGRADE
4 piston calipers fit to them?
Skoda 105 120 130 135 136 front brake calipers left right NOS https://oldtimer-shop.eu/wp-content/uploads/2021/11/1446-3_3.jpg https://oldtimer-shop.eu/wp-content/uploads/2021/11/1446-3_1.jpg
Skoda Felicia Front Shock Absorber pinch bolt problem.....
The General Purpose does not works all the times, the rust can be removed with Vinegar or Coke (when the object can be submerged) or a Rust Penetrant product or desolved with Paint Remover (Spray or Gel). If you don't want to use torch use a powerful Heat Gun in the second scale (1800 W and 650 'C).
Felicia AC to Favorit
You are right but a standard air filter box (02:27) can work even with a turbo 195 Hp Although some guys do it different (01:26)
Felicia 1.6 Custom Gauge Cluster
I don't think that he is going to do a ton of job and then sell it, who's gonna buy it except if it's a ''crazy'' guy which likes something ''unique''? Privates sometimes buy project-cars but only if they have the knowledge, car sellers very often refuse to buy them and many times make derogatory comments because: 1) they don't know 2) they trying to lower the price too much. Many Americans spend even 2-3 years building a car (usually Muscle Car) but "it's for Lifetime'' as they say.
I use this when it's time for extra ''outside'' fuse, no problem with water-dirt etc. After many-many tests with many kinds of air filters-POD's (sponge-gauze) etc i returned to the factory air box with K&N filter with the tube that brings fresh air inside from the grille. With all the other patents i had noise plus hot air from the engine bay to ''feed'' them.
Skoda Favorit custom dash cluster I have also found this: https://phexsys.rajce.idnes.cz/Katalog_grafiky_-_Felicia/ Here are some other for Felicia. https://phexsys.rajce.idnes.cz/Felicia_gauges/ Do you like them?
No swap engine. https://www.skoda-storyboard.com/en/press-releases/skoda-felicia-kit-car-1995-the-next-chapter-in-an-international-success-story/ The most significant changes compared to the production car were under the bonnet: When ŠKODA MOTORSPORT was developing the ŠKODA FELICIA KIT CAR, the team not only had the tried-and-tested OHV engine with a capacity of 1,300 cm³ at its disposal but also an engine with a higher 1.5-litre displacement. It was with this engine that the car was ultimately homologated. Twenty-five years on, the outputs of 136 and 156 hp may seem modest, but the engines were both reliable and light. Since the competition at the time mostly opted for two‑litre four‑cylinder engines, the cars from Mladá Boleslav and their drivers truly had their work cut out on the international rally circuits. The specialists at ŠKODA MOTORSPORT used the technology of the time to its full potential; the engine’s pistons and crankshaft were forged, it featured OBR multi-point fuel injection, Bosch injectors, Jenswey throttle valves, Champion spark plugs and specially designed sports catalytic converters that did not reduce performance. In Mladá Boleslav, it became clear that the vehicle needed a more powerful engine if it was to be a regular winner in its class. Thanks to the brand’s existing affiliation with the Volkswagen Group, the designers were able to use an OHC four-cylinder engine with a 1.6-litre displacement and multi-point injection, which also made its debut in production vehicles with the winged arrow at the same time. Volkswagen itself had never used the engine in racing, so ŠKODA MOTORSPORT in Mladá Boleslav was almost entirely responsible for developing it. The pistons, connecting rods and crankshaft of the cast-iron four-cylinder engine were forged, and a new camshaft was used for valve timing. The resulting output of 174 hp meant an increase of eighteen brake horsepower compared to the heavier 1,500 cm3. The greatest advantage of this engine, however, was its wider power band.
That's the best !
Let me inform you that the Hillbillies and the Rednecks (moonshiners) back in 1920 era were the first which started improve their cars ( horsepower, bodywork, suspension, bigger rims and tyres) not only for escaping from Police cars but they invented the drifting and the racing in oval tracks (NASCAR). Without them as pioneers the World of Cars and rhe Customisation would be much different than it is now so we must respect their herritage.
Some years back i had stored links from some CZ stores about these aftermarket gauges but i lost my interest when i heard about problems with the main red needle alignment-the led light which have-the reflections from the sun in those chrome rings etc. With Paypal payment you have more security in payment with e-stores.
This way and if they are many this way
The factory has made many tests in many road situations, the driver that buys parts and tries to make them work together he gambles. It may work but it may not, so what's next? Drive an unbalanced in brakes car or go to the garage and start again from the beginning? I have seen many videos from USA that drivers had to make again and again tests and corrections (and of course extra money) to their cars after making patents upgrading their brake system. Personally (and maybe some other driver too) have not the luxury to test again and again my car in a track to find what's wrong and pay again and again money to correct things. If 3-4 drivers in the C brand forum make a specific patent and didn't worked to all of them then the 5th that thinks to do the same it doesn't take a huge risk? In Greece we call them ''volunteer suicide guys". All i am trying to say to @vucko1011 is to ''walk in a certain path" and don't make gimmicks.
As for those fance chrome rings that i mention before: https://www.ebay.ie/itm/222783693828 These are RS style https://www.skodateam.cz/bazar/?row=9gt These guys from si.onlinecheapsales.ru can not send items in Croatia? https://shop73002.abcdaustin.org/category?name=budíky škoda felicia They have Credit card and Paypal payment.
