Everything posted by pab567
Update infotainment system?
@Dahaniel to get SmartLink you need to exchange at least glove box unit and display. Pls share VIN so I can check and share more details.
Amunsen MIB1 Firmware
Download link sent in PM
Swing System Update
I sent you download link on PM
Firmware Update for Skoda Swing
Download link sent on PM
I need Bolero Update :-)
Of course there is SD slot, it is located inside the glove box. Look into your car manual. Basically do not use USB but SD and follow the procedure: 1. format SD (max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
Amundsen MIB2 Firmware Update
Skoda RNS510 sw update
There is a newer software available for your unit (5274) but unfortunately you will not get any features. If you want new features and more modern look I suggest to swap with MIB STD2 PQ unit.
Swing update 8755
Download link on PM
SWL Installation loop
You have download link for 6276 on PM. AFter reflashing with 6276 you need to re-install maps.
H10 is not the number I am looking for. If you don't know how to check HW version you have then pls post picture of a label from upper casing. Yes, 6276 is the right SW for your unit
Skoda Swing Firmware Update - MU 8755
Pls specyify part number and current SW version
MIB2 retrofit on an MY2015 L&K
Australia is not an issue at all You have Columbus MIB1 part number 5E0035045D, without DAB, without SIM, USB part number 5Q0035726C and unfortunately you have CANTON amplifier. To get OEM navigation and possibility to display OEM maps in Virtual Cluster (Active Info Display) the best option IMHO is Amundsen part numer 5Q0035864C / 565035864. Unfortunately you have to replace CANTON amplifier as well. If you want to have Apple CarPlay supported as well you need to exchange USB port, too. If you are interested pls contact me on PM.
I'm sorry but I don't use toolbox so can't help you more...
Amundsen mib1
I think it's quite easy - very few peaople have time today to ready all the threads, especially if someone opens a new thread instead of posting a message in one of existing threads of the same topic. I can honestly say I react only if somebody pings me like @PetrolDave did. I sent you donwload link on PM.
Need help understanding different quadlock connector types.
Usually it's not, with very few exception where same car in year X had old unit (RNS315, RNS510 etc.) and in year Y (Y>X) had already MIB STD2 PQ
52 pin is used in MIB units, 40 pin is used in RSN series
- I need Bolero Update :-)
Old check your PMs. @oldjohn ghost screen is 99% HW issue, digitizer to be replaced.- Amundsen MIB2 Firmware Update
Link for MST2_EU_SK_ZR_P0253T on PM- Aftermarket head unit that works with dynamic sound system / underseat amp
Just adjusting both coding and adaptations.- Replace 8" to 9.2" for MIB2 Amundsen to MIB2.5 Columbus
Change adaptation channel "WiFi_Client_HMI" to "On". Make sure NAD module is turned on in coding (I think byte 15, bit 3, but not 100% sure).- Replace 8" to 9.2" for MIB2 Amundsen to MIB2.5 Columbus
I can try... @magiel pls post VCDS adaptation channels map or OBD Eleven backup from 5GF unit with coding and adaptations.- Amundsen MIB2 Firmware Update
Link sent on PM- Stereo screen failure any help plz???
6V0919604 as expected. Replacement is piece of cake, all you need is 4 pieces of removal keys. - I need Bolero Update :-)
