pab567
FREEDOMTech
Everything posted by pab567
  1. All check you PMs
  2. You have the most recent SW I know. Unfortunately 819x and 820x units do not support SmartLink at all - if you want it then unit must be exchanged either to Bolero 840x/842x or Amundsen 864x/874x (x means letter one of A, B, C).
  3. Retrofir to Bolero / Amudnsen is possible, approx. cost 550-600 EUR.
  4. I have no SW update for Swing at all 😞
  5. It can be done but as dashboard is different you need either to have dashboard replaced (expensive!!!) or reworked (requires some tools and manual skills) or you have to install SD reader in a different place, e.g. in glove box which requires extra harness to be used. Approximate costs 500 GBP.
  6. As a matter of fact in most of such cases it's enough to re-install software.
  7. Due to high number of requests let me make some short summary of units that can be installed in Octavia III cars. I have focused only on MIB2 / MIB2.5 units, to indicate differences between them. Simplified Bolero MY15 unit 5Q0035819 (without DAB) or 5Q0035820 (with DAB) Simplified Bolero MY16 unit 5Q0035819A (without DAB) or 5Q0035820A (with DAB) Simplified Bolero MY17 unit 5Q0035819B (without DAB) or 5Q0035820B (with DAB) Simplified Bolero MY18 unit 5Q0035819C (without DAB) or 5Q0035820C (with DAB) Bolero MY15 unit 5Q0035840 (without DAB) or 5Q0035842 (with DAB) Bolero MY16 unit 5Q0035840A (without DAB) or 5Q0035842A (with DAB) Bolero MY17 unit 5Q0035840B (without DAB) or 5Q0035842B (with DAB) Bolero MY18 unit 5Q0035840C (without DAB) or 5Q0035842C (with DAB) Bolero MY19 unit 565035840 (without DAB) or 565035842 (with DAB) Amundsen MY16 unit 5Q0035864A (without DAB) or 5Q0035874A (with DAB) Amundsen MY17 unit 5Q0035864B (without DAB) or 5Q0035874B (with DAB) Amundsen MY18 unit 5Q0035864C (without DAB) or 5Q0035874C (with DAB) Amundsen MY19 unit 565035864 (without DAB) or 565035874 (with DAB) Columbus MIB2 unit 3V0035020x (with DAB, with regular Bluetooth, without LTE Modem) Columbus MIB2 unit 3V0035021x (with DAB, with premium Bluetooth, with LTE Modem) Columbus MIB2 unit 3V0035043x (without DAB, with regular Bluetooth, without LTE Modem) Columbus MIB2 unit 3V0035044x (without DAB, with premium Bluetooth, with LTE Modem) Columbus MIB2.5 unit 565035020x (with DAB, with regular Bluetooth, without LTE Modem) Columbus MIB2.5 unit 565035021x (with DAB, with premium Bluetooth, with LTE Modem) Columbus MIB2.5 unit 565035043x (without DAB, with regular Bluetooth, without LTE Modem) Columbus MIB2.5 unit 565035044x (without DAB, with premium Bluetooth, with LTE Modem) All MIB2 units (as well as Columbus MIB1 which is not listed here) work with 800x480 pixels screens, either 6.5 or 8 inch. MY15 unit support MirrorLink only (no support for SmartLink). SImplified Bolero units do not support rear view camera and voice command. Simplified Bolero, Bolero and Amundsen MY15 and MY16 have old style (rotating, monochrome) menu, with only 1 skin having 5 memory buttons in radio and phone menu. They don't support for APP key in 8 inch FL screens. Simplified Bolero, Bolero and Amundsen MY17 have old style (rotating, monochrome) menu, with 2 skins having 5 or 6 memory buttons in radio and phone menu. It may also support Media Command (depending on FEC.SWaP codes installed). Simplified Bolero, Bolero and Amundsen MY18 has both old style (rotating, monochrome) and new style (pictures, color) menu, with 2 skins having 5 or 6 memory buttons in radio and phone menu. It may also support Media Command (depending on FEC. SWaP codes installed). Columbus units have built-in DVD drive and HDD for maps and audio / video files. Only Columbus units can play video files from USB/CD/DVD/SD. Every MIB2 Columbus unit can be reworked into MIB2.5 unit if required. MIB2.5 Columbus requires new 9.2" screen 5E0919606D. Every Columbus unit can drive directly subwoofer and central speaker (although this setup is not officially supported by Skoda). "x" at the end of Columbus units model number is letter A/B/C/D. Can also be missing. It makes no difference, just indicates original SW release family. Every of listed above units can be reworked into Plug&Play version (no need to visit SKODA dealer).
  8. As some of you have probably realized I'm crazy about converting factory radio / navigation into Android tablet. To be more detailed: in adding Android tablet functionality into factory radio / navigation system. First time I made in in my Superb II MY12 with Columbus. Second time I added this feature to Bolero in my Fabia III. And now I have adopted Amundsen MIB STD2 infotainment system (from new Yeti) to be used in the same Superb (I was a bit tired with Columbus) and equipped wit with Android 4.4.4 module. Disadvantage 1 - you have to change gateway (as this system has address 5F which cannot be coded in old gateway) Disadvantage 2 - you have to find somebody who will take care of Component Protection which is not so common yet Disadvantage 3 - you have to buy SD card with maps (goodbye old good days of updating maps at no cost in Columbus) Disadvantage 4 - no climatronic visualisation Disadvantage 5 - no CD/DVD reader Advantage 1 - something new in the old car Advantage 2 - it has built-in bluetooth Advantage 3 - reverse camera can be connected without any adapters Advantage 4 - you can probably activate and use MirrorLink/AndroidAuto (probably as I have not checked it yet) And it's way easier to extend it with Android table funcionality comparing to old Columbus. I will post some pictures and videos next week.
