Crasher
Everything posted by Crasher
  1. On these later cars with the Digital Service System, what is required and desired can be printed out as a job sheet by the dealer or an independant garage which is registered with erWin for DSS access.
  2. I live about quarter of a mile from a roundabout on the A610 where it changes from SPECS controlled 30 to a so called 40 dual carriageway which was national speed limit and after a set of lights, the local ****s on two or four wheels use it as a drag stip as there are no side roads and speed traps are visible from a mile, in summer I can't have my rear windows open without being deafened and there are two thick rows of trees and a dirty great hotel to deflect the noise. When I walk down there at the weekend to get a paper, you nearly need ear defenders and the emergency vehicle sirens drive you mad in the specs area, one a minute. What these ****s don't realise is they are becoming the reason for their own demise, because they are pushing the limits, the law is cracking down but they are just too stupid to know or too ignorant to care.
  3. I would suspect it is supporting a loose heat shield and the mechanic didn't think it through.
  4. It is in the exhaust manifold before the turbo accessed from above.
  5. 01348 (P0544)- Sensor 1 for Exhaust Temp Bank 1 (G235) - Circuit Malfunction This is the EGT sensor in the exhaust manifold at the turbine inlet, VAG part number 03P 906 088 A and retailing at £179.23 at a Skoda main dealer. These are available aftermarket from reputable companies such as Bosch, VDO, Hella, NGK, Pierburg etc and a common failure.
  6. What is the cars VIN or private message me the reg?
  7. We will only fit genuine VDO from ECP (for the four cylinder, the 3 cylinder is Delphi and even genuine VW ones can fail immediately), they have over 10000 in stock which is in excess of £6m retail, no company in their right mind put that much into stock if they are not going to shift them quick.
  8. Spotted this developing on a Yeti with a CAYC last week when doing the fuel filter and he immediately rebooked for a new pump before further failure as he has read about this and understood.
  9. 1 hour minimum charge, straight across the entire service industry from plumbers to lawyers and everyone accepts it except when it's us grease monkey's doing it and all we get is "your ripping me off", just because we are motor trade!
  10. No AMM/MAF or MAP but it does have an Inlet Air Temp Sender G72 and a Fuel Temperature Sensor G81 and the G81 can give incorrect readings, does the MVB value make sense?
  11. These are a very troublesome engines with injectors and the EGR unit being a very common problem, get the engine ECU code read and if nothing comes up, ask for deeper analysis of the EGR system and injector balances.
  12. That will be the CJZC or D engine, these have a toothed belt for the pump. These should be checked during inspection services and the official change interval 120000Km as is the cam belt change, the exact wording cut and pasted from ELSA being Coolant pump timing belt: Replace Applies to all petrol engines with toothed belt for coolant pump Every 120,000 km Toothed belt and tensioner pulley for camshaft drive: Replace Applies to all petrol and diesel engines with timing belts --- Every 120,000 km Every 120,000 km there is no age change point listed by VAG Germany for ANY petrol or Diesel engine with a cam belt, this up to 2009 four years and 2010 onwards five years is a figment of VAG UK's profit enhancing imagination; the trouble is we have to stick to it as we recommended otherwise and one did fail, we would look stupid. This is copied and pasted from Elsa ( a bit edited as well) where it contradicts the previous info Intervals for CHANGING THE TIMING BELT and TENSIONER PULLEY TDI Common Rail CUSA, CUSB, CUTA, CYZA, CYZB Every 210,000 km Every 120,000 km Applies only to diesel operated in dusty countries. petrol engines 1.0L SRE 1.0L TSI 1.2L TSI 1.4L TSI 1.6L SRE CHYA, CHYB CHZB, CHZC CJZC, CJZD CZEA CWVB No prescribed change interval, Toothed belt drive with test interval, see "Further time- or mileage-dependent additional work"
  13. All EA888 engines seem to do that.
  14. I looked it up on ETKA, I am a VAG specilsist. They are beam deflectors and are specific to right hand drive Octavia NX and NN but confusingly have a 5E part number prefix, on an ETKA search they are only used on the NX and NN
  15. The Skoda mask kit is 5E3 941 981 A and costs £20.24
  16. Yes, I had to take another rack on my account whilst the other one went back to Germany about about 3 months later received a credit but no explanation, not a word of apology or an offer the cover the expenses of replacement... not great service; ever since Bosch took over ZF Lenk system the backup service has disappeared. It is a purely hydraulic rack so I have no idea what had been assembled incorrectly inside at least I hope it was incorrect assembly as if that could randomly happen there are a lot of Golf 4's, Octavia 1U etc on the PQ34 platform out there with a potentially lethal fault.
  17. Might be.... 😁
  18. Powerflex offer their PFF85-501G front bush which is adjustable, I am not sure if I am allowed to post a link to my own eBay page? They are a little fiddly to use but very effective.
  19. I have to admit I and probably most mechanics in the UK have little or zero experience with E85, we have only just got E10 and that is already causing some odd issues with the fuel trim window being exceeded by 10% and causing an error. When you are back on E10 (I assume) I will be able to help better.
  20. 16555 (P0171) - Fuel Trim; Bank 1: System Too Lean Can the modification be taken out of circuit?
  21. Last year I fitted a brand new (although still exchange) ZF K S01 001 000 from Bosch equivalent to the revised VAG number 1J2 422 063 M which was £900 + VAT trade When I started it up it did this
  22. Good battery then
  23. Sorry, I don't have the time to edit this to look neater VRM: SF03EVR Make: Skoda Model: Octavia Engine Size Description: 1.8 Exact CC: 1781 Vehicle Year: 2003 Manufacturer Version Code: 1U Vehicle Type: Car Derivative: vRS Colour: RED Steering Position: Right Hand Drive Body Style: Hatchback Doors: 5 Doors Drive Type: Front Transmission Type: Manual Gears: 5 Gears Engine Size: 15 Fuel: Petrol Fuel Delivery: Turbo Injection Valves: 20 Valves BHP: 180 KW: 132 Engine Code: AUQ Cylinders: 4 Cylinders Weight: 1810kg VIN: TMBER41U538683162 Engine Number: AUQ055417AUQ Date Of Registration: 01/03/2003 Model Version Date Range: 1B (10/2000 - 12/2008) Search Increment: 1 Dvla Model: OCTAVIA RS EVSpec: 18479 Vehicle Guid: C530D45E-FE2B-425A-B426-4F46F8F66DAB Vehicle Id: 20650 DVLAENGINECODE: AUQ Vehicle Type Number: 15293 Engine Size Litres: 1.8 Dvla Make: SKODA Vehicle Identification No. TMBER41U538683162 Model octavia rs OCT Date of production 29.10.2002 Year 2003 Sales type 1U25R4 Engine Code AUQ Transmission Code EHA Axle drive 5S Equipment HV Roof color 8T Exterior color / Paint Code 8T / F3K Special editions E0A no sales compaign version Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable) Vehicle class differentiation powertrains/platform parts 0CH Vehicle class differentiation -1U0- Emission standard 0GG Emission standard EU4 Trailer hitch 1D0 Without trailer hitch Airbag 4UE Airbag for driver and front passenger Activated carbon canister/gasoline particulate filter 1E1 Activated carbon canister Overhead storage compartment 7N0 Without overhead storage compartment Antennas 8L3 Roof antenna Exterior mirror adjustment 6XD Exterior mirrors, power-adjustable/ heated Left exterior mirror 3BF Left exterior mirror: convex, power-adjustable and heated Right exterior mirror 3AV Right exterior mirror: aspherical, power-adjustable and heated Drive type 1X0 Front-wheel drive Equipment lines A8F Sports equipment Rear brakes 2ED Disc brakes in rear Batteries J1L Battery 280 A (60 Ah) Front brakes 1ZN Disc brakes in front (Geomet D) Components with special surfaces 6FB exterior mirror housing in colour of vehicle Controls (steering wheel/steering column) 4LA Without control element Beverage holders 4M6 Beverage holders Component sets for country-specific prescriptive standards B0N Part set, complying with vehicle type for Great Britain, various parts Brake pressure regulator 1H0 Without brake pressure regulator Brake systems 1AJ Anti-slip regulation (ABS/ASR/EDL) with electronic differential lock (EDL) Owner's manuals 0VF Information kit in English Heated door lock cylinder 9X0 Without heated door lock cylinder Brake pad wear indicator 9U1 Brake pad wear indicator Heated washer nozzles 9T0 Without heated washer nozzles CD-ROM/DVD/SD card 7QA Without CD/DVD for navigation CD changer/CD player 7A2 CD changer Chrome package QJ0 No aluminium/chrome package General operating license additions C00 Operating permit, initial registration Cd-enhancing underbody panel 2D0 Without cd enhancing underbody panel Roof rails/roof rack 3S4 Preparation for roof load rack Roof insert/convertible top 3FA Without roof insert (standard roof) Shock absorption in rear 1JC Shock absorption in rear, sports version Shock absorption in front G85 Shock absorption in front Load-through hatch/ski bag 3X0 not with through-loading aperture Tank filler neck for unleaded fuel/fuel type 2G9 Filler neck module 2 with insert Installation differentiation for vehicle parts 0EJ Installation differentiation for transmission MQ 250 -- vehicle components -- Theft protection system 7AA Electronic immobilizer Inserts 5TC No trim inlay Park distance control 7X1 Park distance control Electric Safety package 9BC Display and warning tone f. opened doors Differentiation for manufacturing process 0FA Standard manufacturing sequence Vehicle type AZ0 Vehicle with production equipment Window regulator 4R4 Power windows with comfort operation and circuit breaker Fire extinguisher 6A0 without fire extinguisher Headlight control 8K0 Without special headlight control Fresh air intake for vehicle interior (with particle filter) 2V1 dust and pollen filter Antifreeze agent 1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C Vehicle specifications F0A No special purpose vehicle, standard equipment Throttle control 0L2 Electronic throttle control Alternators 8GD Alternator 90 A Transmission types/gear shift mechanisms 0G4 Cable gearshift Weight category for rear axle 0YZ Without determination of weight category for rear axle Weight category for front axle L13 Suspension range 13 installation control only, no requirement forecast Base engine T8C 4-cylinder SI engine 1.8 l unit 06A.C Luggage net/bag on backrest(s) 4U1 Luggage nets/pockets on backrests Luggage compartment cover 3U1 Folding trunk cover Tie down straps/net/pocket 6M2 Load safety net cruise control system 8T2 Electronic cruise control system (CCS) Sound insulation measures for outside noises 2B5 Additional exterior noise insulation Transmission specification G0C 5-speed manual transmission Speed alert system/speed limiter 6Y0 Without speed warning system Glove compartment 4Z3 Lockable glove compartment door, with light Center high-mounted stop lamp 8R1 Center high-mounted stop lamp Hand brake lever 6PC Hand brake lever handle in leather Wiper and washer system for rear windows 8M1 Rear window wiper washer system with intermittent wipe Rear axle 0N5 Standard rear axle Rear seats 3NC Rear bench seat/backrest, split folding Heating system/air conditioning system 9AK Climatronic with impact pressure control, CFC-free Main headlamps 8BQ Halogen main headlamps for driving on the left Dashboard inserts U1B Instrument cluster with mph speedometer, clock, tachometer and trip odometer Dashboard 4N1 Padded dashboard Breakaway interior rearview mirror 4L0 Breakaway interior rearview mirror, non-dimming Labels (customer specific or campaigns) 0KA Without decals and emblems Body forms K8G Hatchback Luggage compartment floor covering 6SC Luggage compartment floor covering in needle-punched nonwoven Cassette/CD storage compartment 4W0 Without cassette/CD storage Characteristic map cooling system QS0 Without electronic map cooling system Child seats QA0 without child seat Head restraints in rear 3Q6 3 rear head restraints Head restraints 3J7 Tilt- and height-adjustable head restraints for front seats Fuel tank material treatment 2LB Fuel tank with special material treatment (fluorination) Fuel filling volume 1Z2 Increase in initial standard fuel filling Fuel systems 0F2 Fuel system for fuel-injected SI engine Body measures 5C6 Additional measures for the body Child bench 3V0 without child seat bench Radiator grille 6KA Radiator grille Rear license plate carrier 6P1 Rear license plate carrier (ECE) License plate carrier in front 6W1 Front license plate carrier (large) Paint preservation/transport protection 5K1 Transit coating (wax) Luggage/load compartment floor in rear 3GA Without luggage compartment floor Steering system setup L0R Right-hand drive reading light 8S5 2 reading lights in front Steering system 1N6 Power steering Backrest release 3H0 Without backrest release for front seats Ventilation duct in front VK0 Air duct, standard Lumbar support in backrests 7P4 Manually adjustable lumbar support in front seats Steering wheels 2PX Leather-wrapped sports steering wheel Loudspeaker installation 9VE Digital sound package Steering column systems 2C5 Axial and vertical adjustable steering column Headlight range control 8Q1 Headlight range control Center armrest 6E0 Without center armrest in front Multi-function display/trip computer 9Q1 Multi-function display/trip computer Engine cooling 8Z5 not hot country Engine specification MQ7 4-cylinder SI engine 1.8 l/132 kW (20V) turbo base engine is T8C/T16/T63 Vanity mirror on the left 4SC Left vanity mirror with cover Vanity mirror on the right 4TC Vanity mirror, right, with cover Navigation system 7Q0 not with navigation system rear fog lamp 8TD Rear fog light for driving on the left Front fog lamps/additional headlamps 8WD Integrated front fog lamps Rear floor panel platform module 4P2 Rear floor panel module, type 3 Platform group class 7PB Platform group class 2 Flat-tire spray GR0 Without flat-tire spray Wheel trims 1NL Trims for alloy wheels Wheels C7Q Alloy wheels 7J x 17 Radios 8YP Radio "MID" Tires 215/45 R16 86V H8N Tires 205/50 R17 V Tire suppliers V0A Tires without specification of tire brand Spare wheel/breakdown kit 1G3 Alloy spare wheel with original equipment tires Restraint systems in front 3QT 3-point seat belts in front, with pretensioner and height adjustment Side airbag 4X0 without side airbag Gearshift knob/gearshift handle 6Q2 Gearshift knob/handle in leather Special labels 0SS Labels in English and French Rear combination lamps 8SA Rear combination lamp, standard design Closing/opening mechanism tailgate/trunk lid/rear gate 4E0 Tailgate/trunk lid unlocking from outside Seat belt reminder 9P1 Seat belt reminder, electric contact in buckle Outer seat belts in rear 3ZB 3-point seat belts, outer rear with ECE label Center seat belts in rear 3C7 Three-point inertia reel belt for rear centre seat Gearshift boot/gearshift trim 6R2 Gearshift lever boot in leather Seat trim covers N0T Seat trim covers in fabric "Sport" Seat adjustment 3L3 Manual height adjustment for front seats seat heater 4A0 without seat heater Side lamps 8F6 Dark colored side turn signal lights Key for locking system 8QK Key for locking system Horns 8Y1 Two-tone horn Side and rear windows 4KC Side and rear windows in heat-insulating glass Protective side molding 4B1 Protective side strip Supertone system and successive tone alarm switch control 9J0 Without supertone system and tone sequence control Rear stabilizer bar 0BB Rear stabilizer bar Parking light warning light 8NA without side light warning Front stabilizer bar 0AR Front stabilizer bar Heavy-duty/sports version 2UA Standard design Headlamp washer system 8X0 Without headlamp washer system Intermittent windshield wiper control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds) Mud flaps 6N1 Mud flap in rear Nameplate set 0NB Nameplate set in basic style Special alarm systems 9A0 Without taxi alarm system Fuel cap/fuel filler door closing mechanism 2W0 Fuel filler cap Counterweights for steering wheels 1Q0 steering wheel without balance weight Door and tailgate/trunk lid locking mechanism 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK Type-approval testing countries/ countries with specific requirements B09 Type approval country GB/Northern Ireland Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz Partition 3CA with no partition Doors 0A2 4 doors TV reception/digital radio reception QV0 Without TV reception/digital radio reception Front-end underbody cladding 1SA Without additional front underbody guard Identification labels 1EX Special identification label for EC First aid kit/warning triangle 1T0 Without first aid kit and warning triangle Two-way radio installation preparation 9D0 without preparation for two-way radio system Front seats Q4H Sports comfort seats in front Telephone/telematics 9W0 Without car phone preparation/ installation Additional warning lamps 9TB Additional warning lights (door area) LongLife Service Regime QG1 LongLife Service Regime Thermal energy storage system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating Windshield 4GC Heat-reflecting windshield glass with sunshield Washer fluid level indicator 8W0 not with washer fluid level indicator foot mats 0TD Front and rear floor mats Additional child seat anchorage 3B0 Without additional child seat anchors Ignition locking system/electronic steering column lock 0RA Without ignition/starter switch locking system Auxiliary heater 9M0 Without auxiliary heater/parking heater
  24. My 2003 VRS estate came with factory nav Pr-7Q2, TMC traffic module Pr-PNA and the Multi-function display/trip computer with check control (aka maxi dot screen) and Pr-9Q2 which is still listed as being available under part number 1U0 920 941 C KD0 but is £1250.11. Mine occasionally has a fit and goes all left hand drive and metric on me but resets itself by the next time you start it.
