djmartzian
Everything posted by djmartzian
  1. Thx mate. Maybe another software gremlin QQ: Have you use your profile(Primary - with your key) to add/configure the Secondary account OR the second key that you associate it afterwards with SK Connect empty account?
  2. Hello, I've tried today the above procedure but with no luck. The second SK Connect account has been created prior to try to create and to add a new user/account in the car's infotainment system. Basically I've managed to type in the username and password, but then I didn't find a way to move on after the validation screen with the QR code and SKODA ID profile verification. It's keep complaining about "unable to load the required data. Try again later". I used both keys, one at a time, without luck. What am I missing here? Br
  3. The instructions haven't been updated. The SD card was available with MIB2 and MIB2.5, I think. In our case, with MIB3, we can use an USB memory stick, formatted as FAT32, with one of the front USB slots.
  4. Hi all, Has someone tried to update the radio database, especially the Logos for some Radio Stations that are missing them? The related files and instructions are available in the link below after you type in your VIN no: https://updateportal.skoda-auto.com/en-GB Sadly, none of the procedures worked in my case Bolero SW: 1896. I've also took a look in the German forum, but again I haven't had any luck with the following instructions (just use Google Translate like I did since I'm not good at German at all): https://www.skodacommunity.de/threads/radiodatenbank-update-ist-moeglich.144957/post-2321162 Basically I didn't manage to make that "Load Logo" menu to be displayed, hence to load the dedicated logo for a radio station. The files on the memory stick (formatted as FAT32) are somehow "visible" if I try to access them from the Media, left hand menu. Another question is: How can we check the Radio Database version? I'm asking it because this kind of information isn't available in my case: https://www.skodacommunity.de/threads/radiodatenbank-update-ist-moeglich.144957/post-2321153 Ta
  5. Thx @AndreyZh for getting on bottom of this issue. QQ: Does the car must be added in both 'primary' and 'guest' Skoda Connect accounts? OR is it enough to be added only for the Primary user and the 2-d user just to use his/her ("empthy") account to create profile in car's infotainment system? Br
  6. Thx @Felix2021, as always eager to help. 🙂 I've also attached a screenshot with values for the car in the profile, hopefully these values will helm someone with same chassis and trim. Cheers 🍻
  7. Hi guys, Is this procedure supposed to work on Bolero without the SatNav(Columbus) enabled? My current version of Navigation database is 21.2, based on the details from System information. Thx
  8. Hi @Felix2021, I've did a new Backup in this evening with headlights/Low Beam ON. The same apply, all offset values are set to 0. I've also checked other parameters, data/values have been recorded for them. Would you be kind to check your 4B Backup in Offline mode? Thx
  9. Thx @Felix2021 for your fast reply. Yes, I get the point to follow the backup procedure prior to do any coding on 4B module. Actually I just want to have the "live data" within the backup for future reference (given the "professionalism" which the dealers give evidence) . I'll not touch the coding on this module since I don't want to fry the basic settings. In regards to the procedure, I think you're making reference to: Do you have a backup including the live data or some data inside the live data when offline? If so, search for "Matrix light, calculated offset values" and take note of left and right offsets in angular minutes. But, I've just checked within my backup did last week and all the offset values are set to 0. Is this because probably I did the backup during the day and the headlights were turned Off? Shall I try another backup with Low-beam ON? Br
  10. Hi @Felix2021, Would you be kind to provide some instructions how to do the backup of calibration settings with OBD11 App, please? Thank you D
  11. @varooom, Here they are: Control unit: 19 Gateway System description: GW2020 High Software number: 5WA907530Q Software version: 7099 Hardware number: 5WA907530G Hardware version: 756 Serial number: 26016090202418131100 ODX name: EV_GatewMQB2020 ODX version: 005011 My car isn't PHEV, it's a Mild Hybrid type. Br
  12. Hi @varooom, Do you know if a TPI has been created for this kind of issues? I'm asking because this week my car went to dealer for the software updates (VC received ver5370 and MMI received ver1896), but they didn't want to upgrade the Gateway module (currently my car is running on software version 7099, and from what I can see in OBD11 the ver7300 seems to be available). Even so, they changed the battery(prob due to my complains in regards to fast discarding in less then 3 days) , with the pretext it has been checked and a manufacture problem has been detected with it, but this not required software update. Thank you
  13. Hi @strudlovina, What is it the coding for "turn on steering wheel heating automatically" option? OR are you talking about an extra option within the AC menus? 1 - Module 08 - Air conditioning / heating electronics 2 - Adaptation 3 - Hand heater function during cold start: - (Default value is Active) Thank you
  14. Hi guys, QQ: How did you manage to get Waze in Full screen with Android Auto? Over the past months I've tried different settings and smartphones (Xiaomi Mi10T and Samsung S21) but with no luck. SW number is 1889 on my Bolero unit, w/o the SatNav. Br
  15. @Felix2021, Agree with what you said. A few words in a warning + instructions will save a lot of pain/time for others OR you will think twice before doing any changes in the 4B module. @Avi1407, In my previous post I was referring to the B17D7F0 DTC from 09 - Central Electrics module. I also encountered the same error when I ran 1-click app from OBD11 apps list store. The DTC is still present on my car too. So, please please, raise a separate ticket with Voltas Support ONLY for this issue. More tickets to be raised, more pressure will be on they shoulders to search and to find a fix for this.
  16. I had the same error U112500 in 19-Gateway module before the KLR coding. You said that you disabled the capacitive steering wheel, probably that's the reason your car is missing B17B8F2 DTC. U112xx DTC is hiding the B17Bxxx error. Br
  17. Hi @Avi1407, For this error can you please raise a ticket with Voltas Support guys? I also encountered the same error when I ran 1-click app from OBD11 apps list store. More tickets to be raised, more pressure will be on they shoulders to search and to find a fix for this. Thank you
  18. Yes. You need to run a full scan or a partial scan on Module 19.
  19. Hi @Mario_Delgado, Can you please check with an OBD11 dongle what is the DTC stored in module 19 - Gateway, please? Is it B17B8F2 ? If yes, keep in mind that Skoda is aware of this issue and based on the 2062172.13 Travel Assist sporadically unavailable TPI the only "fix" provided by the dealer is to disable TA. Very disappointing and as you mentioned fingers crossed they will provide a software update soon. I've also been hit by the above DTC in a foggy winter day during a short trip in town. Br.
  20. Hi guys, Does anybody manage to successfully retrofit the Octavia 4 steering wheel on any Octavia 3 car? Does anybody know a place where to buy the LIN convertor OR get in touch with the Russian guy? LATER EDIT: @Krosta , can provide any contacts details for the "master" of the LIN convertor, please? Thank you
  21. Thank you for all the details above. What do you mean by "turning on the indicators" ? Can you give more informations?
  22. Hi, 1. In which conditions the bug started? Did the Instrument cluster display the following messages like "Travel Assist Unavailable" + "SOS failure" during that time? 2. How often did this bug is replicated? 3. Did your car was stopped/parked and you just started the engine OR it was during driving(short trip OR long trip)? 4. Have you turned ON the Travel Assist function by using the dedicated button on the steering wheel before the trip? 5. Do you have an OBD11 dongle to check for errors on the 19-Gateway module, especially B17B8F2: Steering Wheel Touch Recognition Control Module - Sensor malfunction DTC? 6. What did you do to get rig of the messages/errors OR they just "magically" gone away? Br.
  23. Hello, I only can say that the heated function just worked BUT my previous steering wheel it was also heated. The heated function is a factory option in my case.
  24. TSR can only be activated with the SWaP code 😒 More details in the thread below: https://forum.obdeleven.com/post/70584/thread
  25. Hi guys, I'm back to you with a question: Does someone else encountered the below errors/failures? Off course 2 error messages have been also displayed in VC: something with powertrain error and Travel Assist unavailable. Are they something to do with the above coding OR is just a set of annoying DTCs that I should not worry about? 01 - Engine - P164700 - Checking coding/versions of control modules in drivetrain 13 - Adaptive Cruise Control - U112200 - Databus implausible message 17 - Dashboard - U105400 - No communication In this morning the outside temperature drop around 0 degress and from what I can read with the OBD11 the regular battery voltage drops ~11.28V. Can this be the root cause? Thank you
