Everything posted by Kenny R
Auto lights issue ?
All I know is my Kodiaq sits quite happily with autohold on engine running and drive selected. If I apply handbrake, revs drop and feels as is clutch is slipping. If I was going to use handbrake every time I stopped I would also be slipping gear selector into neutral and if I was going to be doing that, what’s the point of having DSG with autohold, might as well have manual gearbox and traditional handbrake lol.
Auto lights issue ?
But does that not put strain on the DSG. Having foot on brake disengages the clutches, with the hand brake on the clutches are slipping.
Winter wheels?
Winter tyres are not just for snow and ice, normal “summer “ tyre compounds tend to go hard below 7°C whereas winter tyres stay soft and grip at lower temperatures. As said All season tyres are a good compromise nowadays and can save the hassle of swapping over wheels/ tyres, but as you say having a set of wheels for winter conditions is a bonus and your good wheels are tucked up nice. It’s all really down to location as to whether you experience winter conditions or not.
Random dashboard warning lights
Sounds like a dead battery.
- Uncomfortable Seats
Skoda Connect / Smartlink ?
https://www.skoda.co.uk/owners/skoda-connect Skoda have the cheek to ask you to pay for this rubbish, and you also need to obtain a data sim at your cost for this service to work. Personnally I wouldn’t bother and use car play instead.
What oil is putting the Skoda when it leaves the factory
Front foglights coming on with reversing lights
It’s not an anomaly it’s part of the cornering fog light function. I’ve found it very handy in my previous Yetis and current Kodiaq to see what is around the front end when manoeuvring in our unlit driveway. Perhaps in well lit areas it’s pretty pointless.
Rear coil springs
Very strange if you haven’t got any rear springs, my 2.0tsi certainly has. What have you got instead?
superskoda coupon
You’ve just missed one of their 20% off sales. Next one probably Black Friday
Auto lights issue ?
Both my previous Yetis and current Kodiaq have lamp out warnings as do all modern vehicles I believe. But being old school I still check all light operations, tyre pressures, oil level, screen wash top up etc at least weekly or before any long journey.
Auto lights issue ?
Sidelights are generally 5W which as stated above, not much brighter than candles.
Under body protection
- Karoq 1.5 TSI Oil Filter
Re battery voltage. Modern stop/ start micro hybrid battery systems as in the Karroq do not charge the battery fully to allow some capacity for the regenerative charge energy to go. Depending if you have a AGM or EFB battery 12.4V is about 80% charge which is correct.- Auto lights issue ?
Yes you can change under car/ lights menu if I remember correctly.- Auto lights issue ?
There is an option to have the lights turn on earlier or later. Don’t forget the headlights are not just for you to see but for others to see you, just let them do their thing and be safe.- About to pull the Trigger - 1.5 TSI Kodiaq SE L
Sorry for the confusion, but in your post on another site you priced items individually including waste bin £30 and rear blinds £205 both of which are included in the family pack for £180.- About to pull the Trigger - 1.5 TSI Kodiaq SE L
The family pack includes rear window blinds and waste bin, so you could omit them from your list. As above, after suffering a leaking sunroof in my previous Yeti, I would never spec a sunroof ever again. The standard Alcantara seats are better than paying for leather.- Rear hissing noise
There’s a snake in your boot, or you’ve got a puncture:) Without attaching a video or sound file of what your hearing, your just going to get a lot of random guesses.- Electrical Faults on 19 plate
The only other question is did your previous cars have stop/ start. The reason being with stop/start micro hybrid systems the battery is never fully charged to allow some capacity for the regenerative energy to go to.- Electrical Faults on 19 plate
Did your previous cars have permanently live 12V sockets, or were they ignition controlled. If you don’t require dash cam to be on 24/7 why not wire it to a ignition controlled piggy back fuse as many have done on here, and there’s a very comprehensive guide on how to as well.- Gurgling sound from rear speakers.
Having seen the exact same problem on here before, and having heard it myself, with the vents blowing air across the mic in the roof causing strange gurgling, whooshing noises from rear speakers, so if it’s not that, as they say on Dragons Den, I’m out.- Gurgling sound from rear speakers.
Sounds like you’ve got the voice enchantment turned on, turn it off or turn down and weird noises from speakers will disappear.- Skoda Service Plan Offer - Ends Monday
Thanks for the heads up, I’ve just signed up as well. Will at least soften the blow with now only having to pay MOT, Haldex Service, brake fluid change next year, and MOT and DSG oil change the year after.- 2.0TDi Common rail throttle valve cleaning
In this post they turned the egr inlet shroud 180° by filing a new notch. - Karoq 1.5 TSI Oil Filter
