MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. Mk3 had one incandescent FL got one LED, which also weren't bright a lot replaced them by Ali bulbs -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=5739366
  2. -> Memory module for Start-Stop button -> Permanently Disable Stop/Start
  3. maybe, but small plastic bag had Škoda emblem printed on it Type-C adapter has none
  4. this combination works, Type-C adapter came with ŠS Mk3.FL 2023
  5. in most cases Škoda provides updates for unlimited period, but technically, max date can be set by FEC(Function Enabling Codes) / SWaP(SoftWare as Product) code written in head unit read this thread -> https://www.seatcupra.net/forums/threads/ready-reckoner-on-the-limits-of-mib2-high-plus-map-updates-lifelong.457561/ check by first your FEC code
  6. 1. mine also isn't Sportline, L&K 2.0 TSI 280ps 4x4 2. yes, will improve, they are ~ 15% stiffer than OEMs 3. optional but highly recommended, as it won't increase installation costs (just search for non DCC version)
  7. as one of tested (with DCC shocks) solution i can suggest Eibach Pro kit from Kodiaq challenge, stiffness without lowering, succeed -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
  8. check the current fuel consumption on the display, all depends on model. i have many times read, D + Auto Hold must be same as N, but that doesn't refers to my 2.0 TSI 280ps DSG7 DQ351, where i can feel strong load to the engine when standing in D, no matter of Auto Hold state consumption in N is dancing around 1.1 liters/hour, while in D/E around 1.5 l/h as result, for 1 minute + red lights i simply move to N and Auto Hold is always Off, to avoid annoying bongs at move D->N
  9. +1 replaced OEMs by Zimmermann part codes -> https://www.briskoda.net/forums/topic/407627-rear-disc-brake-wear/?do=findComment&comment=5306861
  10. @chrisgreen just to add clearness, does he talk about sunshades option for rear doors? which were different as rear doors + rear window part code sticker must be located on the bottom side of the cover
  11. @komoornik not so important, but how about picture or part code at least
  12. +1 however, in my eyes, Mk3.FL as replacement of Mk3, is better choice than Mk4 @MrRich click on link in my signature
  13. Rear Window Sunshade makes cover as a different part (same for Mk3 2016 or Mk3.FL 2023) 3V5 867 769 F 6V0
  14. it were ~ €300 ~ option 3Y3 - Rear and rear side window sunscreens Manually operated. Only available on Hatch Mk3 2016 -> https://www.briskoda.net/forums/topic/449490-noise-insulation/?do=findComment&comment=5268266
  15. @Newbiesuperb as alternative option read also about stiffer springs without lowering -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160 DCC isn't disabled, but difference between modes became less bright
  16. current MY23 L&K had all four incandescent, replaced them to LED https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=5799679 previous MY16 Style had reflectors in the rear https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=4994279
  17. rear Upper Spring Underlay 8J0 512 149 from Audi will test soon front 5WA 412 331 A from Arteon
  18. added 2024.08 links into head post Mib2 - v1.10.52 Mib3 - nothing new ? Mib3+ ? Mib4 - v1.31.52
  19. +3.4% in diameter looks too much visit https://tiresize.com/comparison/ as several years tested i can confirm fitment of 225/55r17 instead stock 215/55r17 which gives +1.5% in diameter +10mm in width +5mm in height
  20. that slow driving is acceptable for foreign travel, but too boring for daily routes bests score: 43.4 mpg / 6.5 l100km -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5863867
  21. sad to hear, but PayPal protection is exactly same level - wrong information on seller's web page cost me 700€ -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
  22. @joek666 search for VW compatible SD card on Ali, haven't tested by self, but also haven't seen claims
  23. had exactly same thoughts, but theoretic i haven't yet got confirmation of compatibility
  24. @Jos49 me too replaced, but together with other improvements -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160 effect can't be measured, but definitely that can't make worse
  25. @bpren @Tankdave OEM 18" is worse choice! Have you open thread which were posted by @Shuggyboatsuperb above? -> https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/?do=findComment&comment=5817816
