MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. Temporarily disable KESSY: Press Lock on the Key Fob, then touch outside of Door Handle for few seconds forever method i have got unplanned, car is just 11 months old - --------------------------------------------------------------- Fault Control unit: 09 Central Electrics Active faults: 2 Inactive faults: 0 System description: BCM MQBAB H Software number: 5Q0937084EC Software version: 0511 Hardware number: 5Q0937084EC Hardware version: H44 Serial number: 0410223540xxxx ODX name: EV_BCMMQB ODX version: 022001 Faults: B147BF0 - Remote control key 3 Movement sensor faulty static Date: 2023-12-11 07:36:25 Mileage: 9862 km Priority: 4 Malfunction frequency counter: 1 Unlearning counter: 14 Terminal 15 status: On Terminal 50 status: Off Voltage: 14.7 V Outside air temperature: -3.0 °C Status Bremslichtschalter (HW): Off Status Bremslichtschalter (CAN): Off Off: not activated Parking light: not activated Automatic high beam assist: operated Low beam: not activated Parking light left: not activated Parking light right: not activated Letzte Weckursache/ Werte [00;2E]: Pin C14 Kessy Weckleitung CAN-Bus_aktiv: On +++ edit 2024.01.22 +++ replaced battery in key fob and KESSY returned, 11 months used battery were 2.99v, new 3.3v
  2. +1 even Kodiaq is step down, but Karoq . .
  3. a lot of codings on 2016. Mk3 and 2023. Mk3.FL have been done by first gen OBDEleven, particular Calipers Service option i have seen in some section, but never used to
  4. scroll down my first post in Mk3.FL codings tread, to the table with Tire Circumstance original/changed values, which are wrote from my 0% standard sized 235/45r18(= 215/55r17) and my winter set, custom choice +1.5%, 225/55r17 in two words, last gives closer to reality values on speedometer
  5. disk looks ok, but tire size too small! -3.8% to OEM sizes 235/45r18; 215/55r17 etc. -5.2% to optimal winter size 225/55r17 omho, this link will give better visualisation https://tiresize.com/comparison/
  6. +1, definitely! lot easier for return, if necessary just some things have no alternative: on Mk3 that were closing trunk from interior knob on Mk3.FL Heating of Steering Wheel Last State Memory, etc.
  7. more likely, i got Gen1 Pro version from friend, which didn't required credits at beginning, but since last year it started to ask them for predefined tweaks, long coding and adaptations still for free
  8. @Gabbo click on link in my signature, it were #1 disappointment when i switched from 2016. Mk3 to 2023. Mk3.FL
  9. @Gabbo on 2023 Mk3.FL Lane Assist, by default, activates only manually, by TA button on the steering wheel i managed to find coding, which activates LA automatically when 60kmh reached, browse this tread -> https://www.briskoda.net/forums/topic/516414-vcds-options-on-superb-iiifl/
  10. we have one of the last VAG model, with physical Start-Stop button, install Memory module and enjoy OFF by default, with the option activate it sometimes https://www.briskoda.net/forums/topic/485940-memory-module-for-start-stop-button/ https://www.briskoda.net/forums/topic/436180-permanently-disable-stopstart/page/2/#comment-5747940
  11. @spurf what steps were done? few years ago, i got similar result, when extracted archive directly to SD card, solved by extract to local PC's SSD and only then copied to SD
  12. also on combustions can be remotely activated heating/vantilation through MyŠkoda app, when auxiliary heater option has been added another useful things are remotely Unlock/Lock doors and checking location of the car, what helped me find my car after accident, when it were transported to unknown direction and Insurance help desk gave me wrong info p.s. built in maps has been never used, i prefer Waze for local, daily routes, and Google Maps for abroad trips
  13. @Robbo12@vizslabob what were the reason of waiting that long? links were available two weeks + ago -> https://www.briskoda.net/forums/topic/518018-columbus-map-update-2024-mib12-high/
  14. 2016. Mk3 had coasting only in E 2023. Mk3.FL by default also in D, but it can be coded out -> https://www.briskoda.net/forums/topic/516414-vcds-options-on-superb-iiifl/ i prefer to have all 3 modes under hand, just by single move of gear stick - 1. D without coasting, lite braking by engine 2. move forward to N for coasting 3. move backward to S for harder braking by engine or quicker starting from standstill
  15. ŠS Mk3.FL can be Lock/Unlock through MyŠkoda app
  16. @Gabbo for 17" check also 225/55r17, fits perfectly
  17. when you did download? last which i downloaded were ok -> https://www.briskoda.net/forums/topic/518018-columbus-map-update-2024-mib12-high/
  18. sorry, English isn't tongue language also for me, but 25+ years long friendship with computers made it obvious for me
  19. @dimushor have you asked your self, for what reason this coding got comment revert changes to original values -> Change (8)Leuchte17TFL R BLK ......... C17 to Daytime running lights - > Not Activated -> Change (10)Leuchte17TFL R BLK ......... CD17 to 100 - > 0 -> Change (8)Leuchte16BLK SLB ......... C16 to Daytime running lights - > Not Activated -> Change (10)Leuchte16BLK SLB......... CD16 to 100 - > 0
  20. confirmation of "never" :) quote from - > https://www.briskoda.net/forums/topic/518018-columbus-map-update-2024-mib12-high/
  21. download then from VW's servers https://www.briskoda.net/forums/topic/518018-columbus-map-update-2024-mib12-high/
  22. my previous 2016.02 Mk3 220ps got VARTA from the factory code on car sticker: J2D = Battery 380A (68 Ah) on battery: 7P0 915 105 12v 68Ah 380A DIN 680A EN/SAE/GS VARTA AGM 612 880 RA Made in Germany JCB BEM Code: 7P0912105 JCB360131V2WJ *205 JCB3G1V2WJJ* and it were replaced under warranty accurately after 4 years, because Start-Stop function gone after 3 # 2020.03.04 replaced by 000 915 105 CC 12v 68Ah 380A DIN 680A EN/SAE/GS VARTA AGM 612 809 RA Made in Germany VAO BEM Code: 000915105CC VA0691022M1XZ *205 VA06JAM1XZL*
  23. no 😞 even radio stations logos manual upload option has been gone in Mib3 when compare to mine previous Mib2H
  24. @superbrex By Nav db title it looks like Mib3
