MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. Ask this man, used one day steering wheel from Audi https://www.drive2.ru/l/548426505403761607/
  2. exactly my thoughts during first two years of owning, but now, after 5 years, when come some fantasies about swap the car, Superb is still on the first place of the choice list. i like exterior and interior design, enjoying dynamic of 2.0 TSI 220ps DSG6, but next will be AWD 2.0 TSI 280ps DSG7, huge amount of space even in hatch, don't like wagons cause they are louder and rear window is always dirt in bad weather. problems with suspension can be solved by replace them to non OEM parts. what are alternatives? Audi A6 + €25k Volvo V90 + €22k VW Arteon + €20k and these won't be loaded with options same as Superb also to list i have added Seat Tarraco AWD 2.0 TSI 245ps DSG7, whit which i can save few k € for exact options list if compared to Superb, but lose little bit space in trunk options list of the current Superb Style 2016 https://www.drive2.ru/l/557894125152633200/
  3. using D->N only when red light is far away to able reach it without press accelerator, when "stop line" is closer i use to opposite tactic - a second or two before press brakes pedal moving DSG stick back to switch from D to S, what helps in brake by engine
  4. The same operation, just initialled manually another trick is move selector back to switch from D to S and back, S without accelerator helps brake by engine
  5. Latest set costed me just 4 euros, previous 53, but yes OEM set will cost several hundreds stock Indirect system gives false or too late warnings
  6. i have seen reports there is no progress bar displayed, but after some hour maps have been updated, new numbers in database info i own lot older Columbus - 8" Mib2 2016.
  7. latest public maps # 2021 25 GB VERS 2021.1_P0440 VW portal: http://vw-maps-cdn.lighthouselabs.eu/vw-maps/P0440_MIB2P_EU.7z Downloadable: 2020.11.07 Files inside: 2020.06.26 Published: 2020.11.23 have tried `i-net radio` in demo car -> Internet Radio in Head Unit
  8. Superskoda's are hugely overpriced, for half of this price can be get two sets from Ali, pair of them install in the trunk and second pair in the trunk cover result is day and night
  9. after battery replace will work again https://www.briskoda.net/forums/topic/488489-new-car-battery-time/?do=findComment&comment=5485684
  10. 45e 3V1 998 001 650; 450mm Superb 3 3v1 955 425 650; 3v1 955 426 450mm 35e 5G1 998 002 650; 450mm Golf 7 ??e 3G1 998 002 650; 475mm Passat B8 15e 1K0 955 429 B tikai gumijas 22e 3397007863 650; 450mm Bosch AeroTwin A 863 S 18e 3V9 955 425 rear Superb 3 Combi in far 2018. got OEM set just for 9.9 euros, this campaign not repeated in Green Motors
  11. perfect! dTPMS from Ali can be paired to another winter/summer sensors set, but they must be from the same producer, even when display device looks exactly same :( order can be changed manually
  12. Congratulations! Crazy Man, in this word best meaning I'm fully satisfied with lot cheaper alternative - 3.61€ 2020 Direct TPMS Set 53€ 2017 Direct TPMS Set
  13. who talked about cheap rubber? there were comparison between different inches - price for same brand/model will be cheaper
  14. never failed to start, but were slower later i have installed Start-Stop Memory module
  15. replaced after 4 years -> AGM warranty replace first signs started about 10 months earlier (Start-Stop almost all the time weren't work) -> Battery monitoring now i have disabled Start-Stop by additional memory module
  16. for 17" i prefer 225/55r17 sits perfect on stock STRATOS 7J ET40 +1.5 % in diameter +10 mm in width +5 mm in height
  17. Search also info about ODBEleven, perfect alternative
  18. Recently added feature in Columbus, Amundsen and Bolero (Model Year 21), tested today in Superb with Amundsen - not impressed at all, there is huge field for improvement: 1. stations switch time takes 5+ sec. 2. user can choose from preloaded Top100, no way to add custom stations. 3. my favorite stations https://www.ehrhiti.lv/ not listed. 4. requires connection trough WiFi tethering. with Android app FMPLAY life is lot easier 1. free 2. no adverts 3. can be add custom stations 4. switching stations from steering wheel 5. starts by self, have to press only [MEDIA] button 6. Customization of stations list view, line by line, columns, how many columns.
  19. Can't say for particular, but all others must be extracted from zip/7z archive
