Everything posted by AGFalco
Drive belt size?
Is the self tensioner working properly? Thanks. AG Falco
Skoda Fabia journey display
Do you have buttons on your steering wheel? They probably wanted your total mileage. Thanks. AG Falco
Cabin filter
Bosch BSC1987435002 M5002 Passenger Compartment will fit. Thanks. AG Falco
- Battery coding help needed
Centre Cap Size
57.1 is the inner hole size of the wheel which need to fit tight over the hub. Centre cap part number is 5E0 601 151. Inner diameter is about 51.9 mm. Outer diameter 55.7mm. HTH Thanks. AG Falco
headlight bulb upgrade
How many headlight bulbs does each headlight unit have? Thanks. AG Falco
Firmware Request MST2_EU_SK_ZR_P0480T
anglais s'il vous plaît
Mileage
1.2 TSI 90 2016 89K Miles 5 door manual gearbox. Had from new. £20.00 VED. Tyres last about 30K miles. Last fuel tank 64 MPG Original clutch & battery. Brakes are all original but about 2/3 worn. Had 10 services. 8 Small and 2 big ( including spark plugs and air filters in the big ones every 4th service. ) No oil consumption between services. Never missed a beat. Never broken down. Apart from service parts. Both lower front wishbone rear bushes have been replaced. One had delaminated. N-S-R brake caliper rubber boot over the piston was ripped. Possible impact damage? So cost for parts less than £50.00. Plan to keep long term. I do try to look after my cars. Thanks. AG Falco
Emergency Stop
some people, not all. Thanks. AG Falco
Oil Service Light
Any good? Thanks. AG Falco
- Possible ECU problems?
2020 vRS 245 - Oil?
GM in the states are having some engine failures and their solution is :- ''After over 28,000 reported engine failures, GM is recommending thicker oil as a potential solution'' From a C5 to C3 oil but the API equivalent. Thanks. AG Falco
2020 vRS 245 - Oil?
If it is a C3 oil then :- ACEA C3''Stable, stay-in-grade oil intended for use as catalyst compatible oil in vehicles with DPF and TWC in high performance car and light van diesel and petrol engines, with a minimum HTHS viscosity of 3.5mPa.s. These oils will increase the DPF and TWC life.'' As apposed to C5 :- ACEA C5''ACEA C5 oils are high performance, lower SAPS lubricants. The primary goal of ACEA C5 oils is increased fuel economy in high performance petrol and diesel engines in passenger cars where advanced after-treatment systems such as Diesel Particulate Filters and Three Way Catalysts are used. HTHS viscosity must be in the range 2.6 to 2.9mPa.s (i.e. low) - typically SAE 0W-20 or 5W-20 and made with Group III base oils.'' The 5W-40 oil I use in the other three cars I run is a C3 VW 502 / 505 oil. This will eventually go in my VW as well after it is three years old. Thanks AG Falco
2020 vRS 245 - Oil?
I have a VW that I bought new in Oct 23. VW recommend a C5 0W-20 oil is fitted. You can also use a C3 5W-30 oil. At the first service in Oct 24 the VW dealer fitted the C3 oil for me. I keep my cars for a long time so the oil I chose is important to me. Details I found were:- VW 504 is a FS LL 5W 30 C3 oil and is better at reducing engine wear with a HT/HS viscosity of 3.5 cP than a C5 oil. VW 508, VW 509 is a FS LL 0W 20 C5 oil has a HT/HS viscosity of 2.6- 2.9 cP. They can improve fuel economy by 1%. Engines using this oil will suffer more engine wear than one using a C3 oil. 5W oil is still a flowing liquid at -30°C. 0W oil is still a flowing liquid at -35°C. Thanks. AG Falco
Oil change reset
Agree with above post or see above. Thanks. AG Falco
Is there an option (via a scan tool) to open/close front windows with ignition turned off
Your chauffeur of course.🫡 Thanks. AG Falco
Leave the car owner behind then. 😉 Thanks. AG Falco
Take the spare key with you? Thanks. AG Falco
Bridgestone turanza tyres
The answer will be NO. Thanks. AG Falco
Are your wheels even suitable for run flat tyres? The code can be on the back or the wheel. ( EH2 ) Thanks. AG Falco
- Reverse not displayed on maxi dot display
Engine oil
Yes. Thanks. AG Falco
