TasMan
Everything posted by TasMan
  1. I'm not 100% sure either on that but I expect it is largely down to the map and maybe some things like injectors, fuel pressure etc ? I could get mine re-mapped up to 170ish but then after near 8 years of ownership I'm quite used to the 140 and never felt it underpowered. A pal had a diesel re-mapped and not long after had turbo failure and a £2k bill, co-incidence maybe.... I'm surprised my model (Tour de France 4x4) wasn't offered as standard with the 170 as it would be quite an attractive model when new. Yep, I'm the same, never dry steer and very cautious of having to mount kerbs etc. I have just had the 4 wheels refurbished a few months back so I'm even more careful to avoid wrecking the job ! Its away for its MOT this morning so will see what that brings...😱
  2. Totally agree, maintenance pays dividends long term and driving habits can save a lot of wear and tear. Its a machine at the end of the day and if its abused by crashing over speed bumps and pot holes and stretched service intervals then it will eventually pay you back with problems ! I'm exactly the same, hate all the speed bumps, often have folk tailgating while I crawl over them. Sounds a nice well maintained car you have, mine is the 140 CFFB which has been more than adequate. I thought about a remap but if it isn't broke don't fix it...!
  3. Any evidence of leaks around the windscreen ? I had to reseal the top of my screen recently, only noticed when I washed the car water running down the inside of the screen (driver side top corner). Before fixing I had water dripping down badly from the screen down onto the steering wheel, seat and into the footwell. A tube of Puraflex 40 from Toolstation has sorted that out, neatly tooled down with a sealant smoother tool. Might be worth checking. Cheers
  4. Interesting summary of issues, fair old mileage (my 2014 4x4 estate on 86k lol). What model and year is yours ? I think I saw on Facebook someone selling an estate that had done 650k miles, mainly airport runs from Yorkshire to London on a daily basis. If maintained they should keep going for many years and miles. I guess when you look at your mileage and the parts/issues its all relative to wear and tear ?
  5. I had bother with rear inner tyre wear on my 4x4 Estate a few years ago, a Hunter 4 wheel alignment sorted that out and seems to have been fine since. The state of the roads don't help, I had the same as you after an unavoidable pothole strike, had to have a new front arm fitted on the passenger side and a further 4 wheel alignment to tweak things. Currently on 86k just now, 2014 plate. No doubt there will be a few things go wrong as the car ages. I've just had to repair the rear parking sensor loom due to a broken wire, and had to reseal the windscreen due to a leak (just bodged with some black PU mastic meantime neatly tooled off lol) Starting to get rust on the rear tailgate from the right hand numberplate lamp area, common issue I think. Great cars and love the 4x4 but not without their issues (clutch slave failure at 4 years old and haldex pump and ecu have all been replaced....)
  6. I've not had the issue myself (yet) but fully expect this to be a problem in due course on my 2014 Estate. I've done a good bit of reading on the subject and have always found fairly good feedback on the repair looms available via Ebay etc. Currently got a couple of repair looms in my watch list and there are some further posts on here which cover the subject. I've just had to do a loom repair on my rear parking sensors, cut out a bit of chaffed cable and jointed either end, back working fine. Wouldn't have thought the door loom would be much different (albeit more in depth to get access etc)....
  7. Hi there, really not sure on this aspect. I've not placed an order as yet but will have a further look before I do. The ones linked in my message further above seemed to be the ones that appear the best option, but without seeing them, can't be sure.
  8. Possibly these (although maybe a bit naff lol) https://a.aliexpress.com/_EvCLQi3 And this centre console tray.. https://a.aliexpress.com/_EHgmcTH Cheers
  9. Hi, this is the one I have in my basket just now, my Superb is a 2014 FL so I'm thinking this should be correct? https://a.aliexpress.com/_EJUWAaf There's others on the site, all quite confusing, some seem much cheaper and others seem to have different shipping options. I guess I just have to bite the bullet and try, I've got a few other things in the basket and all well under the £135 value for customs for a single order... cheers
  10. Thats interesting and a timely post as I have some in my basket on Aliexpress but not purchased as yet, they all look much the same. I've never used AliExpress and have heard about folk being stung by customs, but I believe if the value is below a certain figure you don't get charged. One aspect not mentioned in the linked post is the actual fitting procedure, assume you have to remove the mirror glass to then strip down the mirror housing - how easy is it to pull the mirror out....anyone have any tips or a guide ? Cheers
  11. I've had a fault with the right rear parking sensor for a while and finally investigated assuming it was a dodgy sensor or corroded connector but it turns out to be a one of the wires has been nicked or rubbed through... I'm thinking about cutting out this bad section and soldering fresh ends together, with a short piece of wire if needed to make up the length...I assume that should work pending no other breaks in the wire ? Failing that, does anyone know the part number for the loom ? I've had a search of the forum but couldn't find any previous reference. Thanks Dave
  12. Interesting thread, when my 2.0TDI (CFFB engine) slave cylinder failed, the pedal stuck to the floor and there was quite a bit of fluid leak from the bellhousing. Bugger of a job on a 4x4 with extra labour to dismantle....I'm hoping to run the car a while longer and just hope I don't have this issue again.... ££££££ !!!
  13. It might be worth asking around in case its a batch of contaminated fuel...? Seems odd how after re-fuelling you suddenly have an issue. Its not unknown for fuel stations to have contaminated fuels with water, or fuels getting mixed up at tanker delivery stage. Also, if run very low you could have pulled dirt/air into the system, maybe needing filters changed and purged of air...?
  14. This happened to my 2014 Superb and was early failure of the clutch slave cylinder. I noticed the clutch seemed to be slipping for a few days before then one morning the pedal dropped to the floor and clutch operation failed. Required new clutch, slave cylinder etc @ 4 years old.... There was quite a lot of fluid loss present when the AA guy turned up, had to be recovered to the garage for repair.
  15. Definitely sounds like the normal regen process. You can actively monitor your regens and DPF health via your phone (if keen!). Get a Carista or similar OBD reader and plug it in to the car. Download the VAG DPF app and connect it up via bluetooth to your reader. I found this link quite informative... https://www.hypermiler.co.uk/dpf-diesel-particulate-filter/vag-dpf-review-andriod-vag-dpf-monitor-app I try and allow my car to fully complete the regen process each time, not sure it makes a difference but I'm an engineer with OCD and it just seems like the right thing to do lol... Cheers Dave
  16. Looks like the Haldex coupling unit or differential. Seems a bit caked ? I'd maybe give it a good clean and then monitor for evidence of any leaks. When you mention oil change, I assume engine oil and not the Haldex fluid ? Might be worth checking when your Haldex was last serviced if you don't know the history. They need the fluid, filter changed and pump strainer cleaned every 30k. Cheers Dave
  17. Hi folks, Another gremlin this morning , seems to be related to the driver door, locking seems to randomly lock/unlock. After a few seconds the fob will eventually allow the car to unlock. I can then get the door to lock and it seems to stop cycling. Aware of the drivers door wiring loom issue and will check this out, however I have pulled the code 01038 Central Locking Thermal Protection. Just wondered if anyone else has had this, and whether it was related to the loom or door lock actuator ? These things always come up just before going away on holiday, don't want to be stuck 😱 Phoned local dealer this morning (Ingram Ayr) in the hope of some assistance but they were no help at all, earliest diagnostic booking was August due to lack of diagnostic techs ?!
  18. I tend to run 2.4/2.5 on the front and around 2.8 bar on the rears. This is a compromise between the pressure when lightly loaded or fully loaded. Its definitely helped my tyre wear over the years when combined with a 4 wheel alignment. I got 30K miles out of my last set of CrossClimates and that was with 2 - 3mm left. Is yours an Estate ? I had one pair or rears wear down badly on the inner shoulder, new tyres and a 4 wheel alignment sorted that out, been fine since then. Cheers
  19. Hi, Just checking, was it the BA15S bulbs in your Ebay link that are the correct ones ? Thanks
  20. Hi, Just to note your car will be Gen 4 Haldex at 2014, same as mine. Definitely worth keeping an eye on any further codes and to get the filter swapped out at some point, along with pump strainer cleaned. Cheers
  21. I thought the interval was 30k, however I'm possibly wrong... Skoda don't do it right no matter if you follow their service schedule 😠 In any case, and going by experience and also from others reporting similar issues, reducing the interval to 20k or 2 years should drastically reduce the pump failure issue. The other weak point is the Haldex ECU which corrodes over time due to exposure to the elements underneath. This causes water ingress to the PCB and corrosion and then faults, its almost unavoidable and time/environment related. I am trying to get this sorted on mine just now and will report back in due course. Cheers
  22. Welcome to Skoda ownership! I guess it could be a few things and a search on this forum could give further clues. When the car is idling are is there any noise ? The most common rattling type noise that is reported on here is the dual mass flywheel (DMF) issue. Might be worth a read up on this, plenty on here about the subject, your symptoms might not be the same though. Propshaft damper coupling is also a possibility on a 4x4 but then it would remain at a constantish speed if the car is moving, until you accelerate or slow down...? Worth checking out though. Unrelated - Do you know if your Haldex unit has been properly serviced ? Its my old bug bear from bitter experience. If you are not aware they need the fluid changed every 20k approx and the removable filter changed. Skoda do not have the filter on their servicing system and it never gets done resulting in the Haldex pump clogging up and burning out. If you have a code reader it might be worth plugging it in to see if there are any faults lurking. I use Carista which is very handy. Cheers Dave
  23. Thanks for the replies... I should have been more specific, I'm aware of the Haldex servicing requirements, the bitterness of my pump failure in 2018 despite servicing as per Skoda schedule and getting no support from my dealer took a while to simmer down lol Even telling the dealer about the replaceable filter and the servicing requirements, I was pretty much told "Its not on our system and we don't know about it !!" Since then I have been using an independent with an interval of 2 years and approx 16k miles, well ahead of Skoda's recommendation. After the new pump, filter and fluid fitted Nov 2018 it was done again Sept 2020@16k interval and I was about to get it done this month again just over 2 years@16k miles interval. Hence 4 years trouble free motoring until now. I was wondering about disabling the Haldex via pulling the fuse and whether that would cause any issues until I get it sorted out...? I've been watching a few Youtube videos on the subject and as Del8oy has noted its a couple of bolts to remove. I hadn't realised when you pull off the ECU it is directly linked to the control valve and you can't drive the car any further due to the oil loss potential. Seems a poor design really. Currently looking at my options... can't really afford the car off the road while I send the unit away for repair so will see what I can come up with. If I had better facilities to safely work on the car I would do it all myself, certainly not going near Skoda ££££ ! Cheers Dave
  24. Hi All, After 4 years trouble free 4x4 motoring since replacing the pump on my Haldex unit it seems I have a new issue to deal with.... I have the error code 02248 Valve for controlling clutch operating angle. I am noticing when I pull up to junctions or traffic lights, when in neutral the engine seems to labour slightly for a few seconds and I feel a slight bump at the rear as if something is disengaging. This is what prompted me to check for faults as I suspected a Haldex issue. I have been in touch with Matt at Auto Fault Finder (excellent Haldex Repairs Website) and it is looking like the common issue of a fault with the Haldex controller caused by corrosion on the PCB. Usually repairable but involves sending the controller away for diagnostic/repair. Looking for any advice on the following if anyone has had to do this:- How to remove the controller (I believe it is straightforward enough) ? Until I get a chance to get the controller sent away I am wondering if disabling the Haldex by pulling the fuse is possible ? Fuse 29 is the Haldex unit, often pulled by tuners when remapping on a 2WD rolling road set up to prevent the rears turning. Does pulling this fuse affect anything else ? As much as 4x4 makes for an excellent driving experience with the Superb, it really does seem to be quite a fragile and troublesome option to maintain.... Cheers Dave
  25. Yes, very easy job. I had the same issue and ordered a new button from the dealer and changed it out myself, still working very well with minimal effort pushing the button. Follow the story here.... Cheers Dave
